Old 06-03-2004, 07:48 PM   #1
srgntpepper's Avatar
Dump valve fitting for 63 Safari
Does anyone know of a source for the cast aluminum elbow on the dump valve on the bottom of the coach? Any help will be appreciated Don
srgntpepper is offline   Reply With Quote
Old 06-04-2004, 02:12 PM   #2
Old Style Thetford
Your dump valve is an older style Thetford which is no longer available. Airstream stopped using it in 1964. If the brass (not cast aluminum) is in good shape, you might think about rebuilding it by replacing the 3 internal rubber seals.
As you have probably noticed, modern fittings won't fit on this valve. If you don't have the old hose connections which fit this valve, you'll probably want to replace the whole valve with a modern one.
Good Luck!
63flyingcloud is offline   Reply With Quote
Old 06-04-2004, 03:46 PM   #3
Thanks alot, I have already replaced the three seals inside the valve and it works good!!! The only problem is that the hose fitting(the cast aluminum piece I was talking about) is still pretty much intact, but it looks like the PO had hit something with it, the bottom is broke off, i guess I'll have to fabricate a new one. happy motoring!!!!
Old 03-14-2005, 10:40 PM   #4
1963 safari dump valve gaskets
Where did you get the replacement gaskets? I need to do the same on my 1963 Tradewind brass dump valve. thanks. shivaji@tamoinc.com
Shivaji is offline   Reply With Quote
Old 05-14-2005, 04:01 PM   #5
just matched them up at the hardware store....
Old 06-05-2005, 05:36 PM   #6
Trailer Girl's Avatar
1964 26' Overlander
Nampa , Idaho
Images: 11
Thetford Dump Valve
If these are no longer avail what do we replace them with? I have put a new "gate valve" (?) assembly on the tank- I want to replace this heavy, heavy part with plactic- it weighs almost 7 lbs- I think this would be a strain on the valve/tank assembly- any ideas for a replacement?
Name:	airstream dump outlet.jpg
Trailer Girl is offline   Reply With Quote
Leaking Dump Valve dblee50 Waste Systems, Tanks & Totes 34 11-24-2007 05:28 AM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
Dump valve seal 71_safari Waste Systems, Tanks & Totes 5 04-30-2004 01:43 PM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 03:20 PM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 06:40 PM
