Old 10-18-2006, 09:41 PM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Dump Valve Cap
We have been doing plumbing work on the 79 Excella and had removed the cap from the waste water dump outlet to wash it (Thetford ?). We left it next to the trailer overnight and the next morning it was gone! The only thing we can figure is that an animal must have carried it off as the trailer is in a semi-rual area on a dead-end street so it is not like ther are many potential thieves around. Anyway it iwas white and I believe it is 4 inch in diameter and had a fitting to attach a garden hose on it. Does anyone know if replacements are available?
According to the local RV dealer they are not and I need to put an adapter on it to reduce the outlet to 3 inch? Are 4 inch not made anymore?
New to the RV lifestyle and just don't have a clue.
Dan
Dano57 is offline   Reply With Quote
Old 10-18-2006, 09:51 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Dan
Dan,
Is this what you want: http://www.campingworld.com/browse/s...or/skunum=6383
Just make sure that it fits Thetford.
Bill
Just my personal opinion
Old 10-18-2006, 09:55 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Or call Thetford direct
'77 Sovereign Intl 31' CB
Old 10-18-2006, 10:07 PM   #4
Dano57's Avatar
Edmond , Oklahoma
Bill it look close but I am not sure if it is big enough in diameter but will look into it further.
Lipets, I looked at their website but could not find anything close. But you are right I probably should call.
Dan
Old 10-18-2006, 10:35 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Dan
Dan,
When I purchased the blue boy tank it came with that type of cap which fits my 1979 Safari.
Bill
Old 10-18-2006, 10:58 PM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I got mine at Wal Mart.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-22-2006, 10:37 PM   #7
1960 24' Tradewind
santa barbara , California
Hello dano57 ,
the white cap is a thetford ,the local Rv place here in town has that white cap I think with the hose fitting and a solid cap .They are heavier plastic
and made well ,doesn't mean better ,but just a description of what they are
and expensive as well .I can check for you if you have no luck and ill go by
and measure it as well from the RV store.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 10-22-2006, 11:30 PM   #8
2007 25' Safari FB SE
Suburbia , Sunny So Cal
O.K. I give. Whats the hose fitting for?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 10-23-2006, 03:49 AM   #9
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
This cap has a garden hose fitting allowing you to screw on a hose to let washwater drain on the ground (where permitted) or into a collection container such as a blue boy.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 10-23-2006, 06:03 AM   #10
1976 25' Caravanner
Campton , New Hampshire
Dano57 , not many RV dealers are carring the Thetford line any more but all should be able to order them , they are still made . When you find them you may want to get a set of spares ( hose fitting and cover ) as they are hard to find on the road if one should get lost or broken.
ticki2 is offline   Reply With Quote
Old 10-23-2006, 06:55 AM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
don't panic if you cannot find one, you can make one from a regular 3" thetford hose connector and some pvc parts from the hardware store.
i made one using a thetford connector, 3' cleanout, matching screw in cap and a brass garden hose adaptor. it is a little more bulky than the original but serves the same purpose.
john
you call them ferrets, i call them weasels.
Old 10-23-2006, 05:06 PM   #12
Dano57's Avatar
Edmond , Oklahoma
Thanks for the replys folks. I have checked with a couple of RV places and they want me to buy some kind of adapter to a smaller size. There is a couple of dealers I haven't checked with on the south side of town, I'll see if they can order.
Scott, if I can't find one I may take you up on your offer. John, if push comes to shove I might need to discuss how you built one.
Thanks again.
Dan
Old 10-23-2006, 05:57 PM   #13
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Camper World carries them locally and online. I got lucky and found one on ebay - check there - often there are several of the caps and fittings. Some used - just open the box with gloves on....
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-23-2006, 06:21 PM   #14
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
order and save fuel!
Look right here.
http://www.campingworld.com/browse/s...ap/skunum=4181
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
Tedford dump valve 77caravaner Waste Systems, Tanks & Totes 0 09-29-2002 04:58 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 12:19 PM
