Old 05-01-2012, 09:31 AM   #1
Impala348's Avatar
1984 31' Excella
Lees Summit , Missouri
Dump Valve
Has anyone ever had the pull rod pull out of the dump valve? If so, can it be re-attached, or do I need a new valve?
Impala348 is offline   Reply With Quote
Old 05-01-2012, 10:50 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If it is the entire rod, including the knob on the end that slips into a notch on the blade itself, you should probably replace it. If it happened once, it will again, usually when the tank is full.
Old 05-01-2012, 11:01 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Bill has a detailed account of his experience here with pictures.
http://www.airforums.com/forums/f312...ml#post1070873
Dave
Old 05-02-2012, 05:55 PM   #4
Impala348's Avatar
1984 31' Excella
Thank You Massey and Overlander!. This really helped. I found that it was the coupling from the extension rod to the valve rod. Was able to clamp a pair of vise grips onto the valve rod and dump the tank. This was a Major Victory!! Now, I just have to figure out how to re-attach the extension rod. Hoping I can do it with one hand so I won't have to drop the whole pan under the tanks.
Thanks again!!!
And thanks to Bill for the pics.
