Old 12-04-2002, 09:31 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Dump valve
anyone ever clean the dump valve on their grey or black water tanks? My slide has a small amount of leakeage, and I expect it will only get worse. I have seen replacements, but wonder if there is a good method to restore the seal of these.
Its the standard pull type blade...
Old 12-04-2002, 10:56 AM   #2
74SovereignInt.'s Avatar
previously asked
You might try a search in the plumbing section. I know I asked the same question just a few months ago and got a lot of good feedback. In my opinion I would rebuild them. Mine were easy to get off and clean.
74SovereignInt. is offline   Reply With Quote
Old 12-04-2002, 11:23 AM   #3
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Alan,
One side of the valve is bonded to the pipe. My suggestion is to buy a kit with new seals (~$20). The other option is the buy a new valve at $75 and use 3/4 of the parts (keeping the side bonded to the pipe). This is another "Repair that even Fred can do".
I took mine compeletely apart and scrubbed the rubber seals good and put it back together. Works well for now. I will need to go back and put new seals in at some point. There is a gasket between the two halves of the valve that is the most delicate piece.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 12-04-2002, 11:24 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
THANKS, I should have known the answers would be here somewhere already.
I will try the cleaning methods I read about....that is as soon as the freezing rain stops here.
Old 12-04-2002, 06:07 PM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Alan,
My black valve was leaking and I had to fix it as it was becoming a messy issue. The repair kits contain all of the necessary seals and gaskets. I think I paid 18.00 for the kit. The valve is held together with 6-8 screws. You should be able to seperate the halves enough to replace the seals without cutting any pipes.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 05:26 PM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 03:20 PM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 06:40 PM
Explain this Dump Valve behavior..... Chuck Waste Systems, Tanks & Totes 2 08-28-2003 11:18 AM
