Old 08-21-2003, 08:40 AM   #29
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Sewer Solution to fit 4" outlet?
Looks like the Sewer Solution only comes with a 3" connection. I take it that someone sells a 3" to 4" adapter so I can use a SS on my black tank?
Where would I get one?
TIA!
Don
Old 08-21-2003, 11:15 AM   #30
2004 28' Classic
Kenney , Texas
Re: Sewer Solution to fit 4" outlet?
TIA!
Don
Does that mean that the A/S outlets are 4"? On all models?
Dave Jenkins
K5KX
Dave Jenkins is offline   Reply With Quote
Old 08-21-2003, 11:47 AM   #31
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
My drains are 4", my sewer solution fits it.
When I drain at a dump station, I do not use the sewer solution. I do not think that it is a good idea to use it exclusively.
My black tank needs a " speedy evacuation" to become clean. The sewer solution does not allow this. Residue remains after dumping with the sewer solution system. I like the sewer solution while camping, but if i have to dump at a dump station, I always use the trusty old dump hose.
Uwe
www.area63productions.com
Old 08-21-2003, 12:15 PM   #32
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Interesting product.
Ours doesn't have a grey water but the plan is to add one. To furth complicate issues our balck water is above the floor. Our gray water will be below so I either have to keep the drains seperate before the slinky or I have to work something else out.
What if a one way valve was placed in the gray water drain to the shower? Surely somebody has to make one that is passive. I wouldn't see a need for one on the sinks because they are well above the black water tank.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-21-2003, 12:27 PM   #33
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Our 71 has an added on grey tank. A large diameter pipe comes from the black tank dump valve ( above floor) and terminates in a regular 4" bajonet style dump port. Just near this it is joined by a 2" or 1 3/4 pipen and a small diameter dump valve. Now, the small dump valve should be closed when the black tank dumps, or the contents will go into the grey tank.
Sinks and the shower have a trap, so a one way valve is not needed, onless you hopelessly overfill the grey tank and go up a steep hill.....
Uwe
Old 08-21-2003, 12:36 PM   #34
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
My Scamp 5th-wheel had separate drains for the black water and the gray water. The black water drain was in front of the single axle and the gray water drain was just behind the axle. By positioning carefully, I could reach both without moving the trailer.
I never felt that the separate drains were any problem. I would dump the black tank first, then move the hose to the gray outlet. This layout served me well for years. If I were to add a gray tank to an existing trailer, I would certainly consider separate outlets.
John W. Irwin
WBCCI #9632
Old 08-21-2003, 03:24 PM   #35
drboyd's Avatar
1978 25' Tradewind
Sewer Slution fit on an Airstream...
Here's a previous thread about the SS fit....
Sewer Solution
**Little Boo Boo's** Silvertwinky On The Road... 22 06-05-2007 08:49 PM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 05:26 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 08:25 PM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 06:40 PM
