Old 04-30-2015, 03:52 PM   #1
CAirstream's Avatar
2013 25' FB Flying Cloud
Novato , California
Dump Station Black Tank Rinse Question
Hi,
We have been camping now for a couple of year, I went from never camping in my life to getting an Airstream as my first trailer/RV and now am addicted to camping and spending time in it.
I usually schedule a full hookup campsite before going home as to be able to rinse my black tank throughly. We are planning on camping at Sequoia National Park in a few months and I was wondering if anyone can tell me if I can connect this kind of water hose (picture attached) directly to my sewer rinse connection on the Airstream which I normally use a garden hose for. Any help will be greatly appreciated.
CAirstream is offline   Reply With Quote
Old 04-30-2015, 04:08 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Standard water hose connections work. If you add a short hose flex hose to it and hookup will be easier.
Don't use your drinking water hose.
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-30-2015, 04:08 PM   #3
1986 31' Sovereign
Miami , Florida
It depends, some have a threaded fitting on the end but many have been cut off, leaving bare hose. I wouldn't count on it being available.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
n2916s is online now   Reply With Quote
Old 04-30-2015, 04:11 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Btw, close off the black valve. Fill/ flush for a minute or three, open valve, repeat a few times. Also, if you raise the "curb side", you can get a better flush of the flat bottom of the tank.
Channing
WBCCI# 30676
Old 04-30-2015, 06:00 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
In most cases there are no threads on those non potable water outlets. A couple of things you can do. If the dump station is large and has multiple outlets you can dump the black tank and then pump water from your fresh water tank into the toilet. This is slow, but that will get some clean water into the tank.
If there is a fresh water outlet at the dump station, you can hook up a hose pull it into the bathroom and fill the toilet from the hose. That will fill pretty quick.
Again both of those methods may not be practical since if the facilities are limited, you will back up some traffic waiting to use the dump station.
Keep in mind that dumping a full tank works pretty well. I make it a practice to make sure the tank is full prior to dumping. If it's not full by normal use, I will fill the tank with water from the fresh water tank. I've carried 3, 7 gallon water carriers that I can use to fill the fresh water tank if I'm getting low by my departure date. A large volume of liquid will carry just about all if not all of the waste out of the tank.
Finally if it is a multi-day drive to home, I'll make sure I overnight at a full hookup site on the last day of travel, and flush the tank the morning that I leave.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-30-2015, 06:39 PM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
The ones like that that I have seen I would say no. Those have had nothing but a cut off hose at the end. However, there is a device called a hose thief ( available from Camping World and others) designed for us to attach a hose to a campground spigot that has no hose coupling. It slips over the spigot end and holds with a tapered pressure fit. It allows a standard hose to attach thereby allowing us to fill our tank. I've not had the need yet but if the hose thief would grab onto the end it just might work. NOW, if this happens to be a potable water supply it would likely NOT be advisable to use as a black tank flush. If it happens to be a non-potable and at a dump station I say go for it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-30-2015, 06:40 PM   #7
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
I bought a little blue rubber gizmo, I believe it is called a "water thief" . I have used it several times with those hoses that the threads have been cut off. You can get it on amazon or campers world. It worked very well...
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 04-30-2015, 07:34 PM   #8
CAirstream's Avatar
Novato , California
Thank you everyone for answering my question!
Old 05-01-2015, 06:13 AM   #9
dznf0g's Avatar
Oswego , Illinois
There's another method...but not for the unsure.....
Dump your black as normal.
Leave black valve open.
Lift the end of the slinky above your head (above tank level) while squatted down.
Open the gray valve, while still holding the slinky above the tank levels.
Let water from the gray tank backflush and fill tank black until you hear minimal water rush sound.
Close gray valve.
Lower slinky end to dump opening. (you have a couple of seconds before water flows to end of slinky).
Let black tank drain again.
Repeat 2 - 3 more times.
I have used this method for quite a few years and have never "dumped" on myself nor on the ground anywhere except in the dump station opening. It keeps the black flushed and cleaner than ANY other method I have used. It is much quicker and thus, more courteous, while at the dump station.
-Rich-
Old 05-01-2015, 06:51 AM   #10
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Black tank
I guess one question I have is how one can fill 38 gallons of black tank??? Of course, with kids, lots of guests, maybe on the road for months, this might be possible, but the gray water is always the limiting factor for me. Thus, I empty my black water only when home, then flush until clear effluent is seen from the discharge hose.
I like the idea of using the gray water to flush the back tank, but, I am wondering if having the discharge end of the hose out of the sewer pipe while one is opening both tank valves is an issue which could be illegal....like in California?
I am going to get a "water thief" sounds like a good safeguard if the end of the waste water flush hose has been cut off. Thanks for the tip.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 05-01-2015, 07:28 AM   #11
1976 31' Sovereign
Oswego , Illinois
Another suggestion is after dumping black tank put 10 lbs. ice cubes in toilet & several gals. water, ice cubes will scour tank of sediment, drive to where camping dump, rinse with several flushes. You should see nice white bottom as tank is clean. I did this 1 time last year & my AS is 1976 yrs. old, this was first time, tank, nice white bottom when I dumped. Caveat. Do not leave black valve open when hooked up while using toilet as this lets solids dry & harden in tank.
Old 05-01-2015, 07:47 AM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Consider this: Black water contains human bodily fluids. Gray water does not.
On a ship with an infirmary, such a cruise liner, ALL water from the infirmary is considered black water, even the water from sinks, because the water may contain human blood. In your trailer, if you cut yourself and wash the cut in the sink, your gray tank contents should be considered black water because of the blood in the water. If your four-year-old grandkid pees in the shower, your gray tank now contains black water because of the urine that went down the shower drain.
By the same token, as soon as you cross-connect the black and gray tanks to give your black tank a gray-water rinse, you no longer have any gray water, you have two black water tanks, because it becomes possible for human pathogens to migrate from the black tank to the gray tank.
I'm not telling anyone that you can't use gray water to flush your black tank. But if you do, then you should use fresh water to fill and flush your gray tank afterwards to get rid of any possible cross-contamination.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 05-01-2015, 09:03 AM   #13
Msmoto's Avatar
2007 25' Safari
Images: 135
I fully agree, once the waters mix, two black water tanks exist and both need thorough flushing. Thanks, Protagonist.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
AIR #31871 K4MTL
Old 05-01-2015, 10:05 AM   #14
1974 Argosy 20
Kooskia , Idaho
I am going to be contrary here, but why all the obsession about flushing the black water tank? You are never going to make it clean anyway. The only time I bother to flush the black water tank is when I am winterizing, just to get any possible solids out for a long storage period.
Here is what I have done for 30 years of Airstream RV use:
Hook up the sewer hose, pull the black water dump handle, let it empty.
Go inside and fill the toilet to the brim and then flush it.
Go back outside and close the black water dump valve.
Pull the gray water dump valve and let it drain.
Rinse out the sewer hose and replace.
Wash hands. No, I don't use gloves, booties, haz mat suits etc.
Drive away. Total time is about 5 to 6 minutes.
Blackwater dump station question daninnh Boondocking 11 05-09-2011 07:37 PM
Looking for a "wand thingy" to rinse the black tank. memgrove2000 Waste Systems, Tanks & Totes 7 07-05-2009 09:37 PM
Black water rinse clogged! Resorts Waste Systems, Tanks & Totes 5 02-15-2009 12:30 PM
Black Water Rinse Noise James Schmidt Waste Systems, Tanks & Totes 16 05-19-2007 06:49 PM
