Old 08-30-2010, 01:26 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
dump/collector/outlet assembly
Wondering how all these components are secured together. Looks like the dump valve is simply screwed to the tank outlet...but what about the rest? is the "collector" glued into the valve? pretty sure that the gray water lines are also glued, so those aren't coming out.
The actual problem is that one of the lugs on the outlet to which the slinky connects has broken off. Its still useable...but if another one breaks off, I could be "stuck" with a tank full of badness.
looks like its pvc-glued onto the collector, so that means that to "really" fix, I'd have to replace the whole assembly, cut the gray lines and re-connect w/ those rubber compression joints. correct?
so how is the collector connected to the dump valve? is that screwed, or glued? if glued, I imagine the dump valve, itself, will also need replacing...and would a valterra valve screw pattern match the thetford that's there?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-30-2010, 09:55 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I suspect that everything is cemented except the tank coupling.
If you were to repair it, parts availability would be a problem. That solved, you could either use the rubber "Mission" couplings you mention or cement it using slip couplings.
If it were my trailer I'd cement in a new lug made by filing a scrap piece of PVC.
Old 08-31-2010, 10:01 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
cement a lug...from what? a new lugged fitting, cannibalized? That doesn't seem workable, to me.
I think parts are available for these dump valves...but I question whether it is possible to actually "get at" this one, as it is positioned. Surely, the whole assembly will droop down when its unscrewed from the tank...but how much, really?
I guess I'm questioning if it is the SOP to simply cut the gray lines, and drop the whole thing, whenever any such maintenance is required? re-attach w/ the slip or compression couplings.
anyone know if the bolt pattern on the thetford valves matches that of the valterra?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-31-2010, 10:24 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Just take a piece of 3" pipe and a coping saw and make something shaped more or less like a lug, clean, prime, cement in place using a clamp or rubber band, and file as necessary for fit once the cement is completely dry.
Old 08-31-2010, 11:51 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
"more or less like a lug" ain't gonna work, here. These things have to fit more precisely than that.
you know, it looks like a thetford slinky adapter should fit a valterra outlet...the lugs are just "bumps", at 90-degree increments around the pipe...but it doesn't. Its gotta be "just so".
After looking at pics of the valves on the VTS site, it looks like this valve is has an o-ring outlet...and the flaring out/flange-like shape at the top of the collector is meant to mate to that, is built-in to the collector, and is not a separate glued-on part. which means the only thing that'll fit this valve is another collector exactly like this one...and I've seen Andy at Inland RV state that these collectors are no longer available. So it looks to me that in order to properly replace the lugs on this is to replace the whole kit-n-kaboodle, valve and all.
I imagine its possible to glue up something from standard pvc...glue-on a thetford bayonet ring (still available), and couple that to another type of thetford valve that has a 3" straight outlet. But it might hang down a little lower.
{sigh}
Valterra makes a similarly configured collector, but it probably only mates to a valterra valve, and I'm not sure that a vatlerra valve will bolt to the tank adapter.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-31-2010, 12:20 PM   #6
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
side discharge
90 degrees out of tank
2 cutoff valves
redo it, strap it up tight and life can go on
kennethowens is offline   Reply With Quote
Old 08-31-2010, 01:07 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by kennethowens View Post
side discharge
2 cutoff valves
if life were only that simple....
Its a floor mounted tank. a box, with a hole in the bottom.
Now, I could just rip out the entire bathroom, remove the existing tank, put in a sub-floor mounted tank, drill holes in the floor and frame to completely re-run plumbing for the entire trailer, including a gray tank (absent from this vintage), add frame extensions to box it all in...THEN proceed w/ your simple instructions.
and I would...except for 2 missing prerequisites...those being "dollars", and "cents".
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-31-2010, 01:27 PM   #8
modarch's Avatar
1967 17' Caravel
Thompsons Station , Tennessee
I have one of these collectors on my '67 Caravel. Mine is the same as yours, except I have grey water entering only one one side where yours looks to have two.
My collector also had the Valterra (or Thedford) with the lugs broken off. I found this link and did the same thing this guy did- worked like a champ.
http://www.airforums.com/forums/f444...fix-50202.html
It will work for you too.
You can buy new collectors- InlandRV makes new ones, but they are $$.
The valve screws to the bottom of the black tank, and then the collector screws to the valve. The only thing cemented is the grey water lines feeding the collector.
Hope this helps...
My restoration photos on Picassa:
1967 Caravel
modarch is offline   Reply With Quote
Old 08-31-2010, 01:31 PM   #9
1975 Argosy 24
Malakoff , Texas
did not mean all that....
a 90 coming out of the tank....sched 40 and a few fittings...and new Thetford
dump valve or two.........we aint talking big bucks here.........besides - from the pic
you have it opened up for repair
Old 08-31-2010, 01:41 PM   #10
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Would this double connector work?Double Collector 89-8297 [T1013] - $11.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 08-31-2010, 02:17 PM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Hope this helps...
yes, that does help. thats the exact situation.
not sure how confident I am in using "that stuff they use on windshields" for glue, though. But perhaps there's a way to get another piece of abs plastic pipe to mate, that can be glued w/ abs cement. (which, I'm nearly certain will work to secure 2 pieces of abs ).
how would you connect a "90 coming out of the tank" to the existing flange, which is meant to accept the particular valve in the pic? and even if you can do that...a 90 would convert the vertical drain to a horizontal one...within the confines of the frame cavity. You could run a pipe from there over to the main frame rail...then what? cut a hole in the frame? doesn't sound easy...or prudent to cut a 3" hole in a 5" structural member.
Originally Posted by arodriguez60
Thats the right idea...but I don't think that'll mate to my valve. looks like an instance of "male-to-male", rather than "male-to-female". So you'd have to replace the valve...and as I said before, I don't know if a different valve would mate to the tank flange.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-31-2010, 02:19 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
You may have missed the key piece: "file as necessary to fit."
Some of the dimensions are critical. Some are not. PVC is easy to shape with a file. If you can't get it to work you can always try something more drastic.
Old 08-31-2010, 03:12 PM   #13
1975 Argosy 24
Malakoff , Texas
down&OUT
not too difficult
Old 08-31-2010, 03:37 PM   #14
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
not too difficult
well, you can draw pipes any which-way, but getting them to actually mate to what is actually present is...difficult. or expensive. or both.
Air:291
Wbcci: 3752
'73 Safari 23'
Vintage 1962 Airstream Tradewind 24' MUST SEE COLLECTOR eBay Watch Airstreams on eBay 0 03-24-2010 09:40 PM
Thetford Collector (original 67' Caravel) 1967-Caravel Waste Systems, Tanks & Totes 5 04-07-2009 10:07 AM
Entire Y assembly and dump valves FELL OFF! dalefox Classic Motorhomes 7 10-23-2008 02:52 PM
