Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Prev Previous Post   Next Post Next
Old 02-17-2003, 02:27 PM   #1
Profile:
Drain valve too low
The drain valve on my 92 Sovereign 21 ft with 14 inch tires is too low to the ground which causes two problems: One, most sewer connections at campgrounds are too high for me to fit the sewer hoses in so that they will drain properly and two, the drain valve keeps hitting obstructions, even some speed humps, and busting things loose (nasty).
Does anyone know how to raise the height of this unit? Thanks.
wayner1239 is offline   Reply With Quote
Thetford Drain Valve - Blackwater JHBurns100 Waste Systems, Tanks & Totes 15 04-07-2009 10:39 AM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 05:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 11:03 AM
Plastic water drain valve Waterman Plumbing - Systems & Fixtures 5 10-29-2003 11:51 AM
low drain points Raptorrider2001 1999 Safari 18 12-12-2002 05:17 PM
