Old 10-18-2016, 09:03 AM   #1
1976 31' Sovereign
Oswego , Illinois
Question Drain line after dump valve
Is there a way to access plastic pipe after dump valve w/out removing belly pan on 1976 rear bath AS? The pipe goes thru side of frame just forward of bumper then fitting for hose on end. This pipe came loose aft of black tank dump valve inside where thru frame under black plastic liner that hose stores in and shore power cord stores. Can this liner be removed after removing bumper then granting access to pipe? Liner can not be removed as is. Bill
Old 10-18-2016, 09:44 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Not sure about 76 but on my 73 and 71 you access the dump valve drain pipe junction by drilling out the rivets that hold the beltline trim and banana wrap so you can remove that curved section between the aluminum rear side section and belly pan. There is also a small section of belly pan to remove between the trailer frame and banana wrap.
Old 10-18-2016, 01:08 PM   #3
1976 31' Sovereign
Oswego , Illinois
Smile
Disregard this post as found info in AS service manual. Remove bumper & hose storage liner, there is what looking for. thks. Bill
Do You Need to Dump the Black Tank After Driving Home? mrpettit Waste Systems, Tanks & Totes 11 12-01-2014 03:56 PM
Line Drain Valve replacement jcramer Fresh Water Systems 2 08-03-2010 10:13 AM
1964 Overlander Dump Line Ginder75 Waste Systems, Tanks & Totes 18 07-12-2010 10:02 AM
