10-26-2011, 07:27 PM
2016 30' Classic
2009 25' FB Flying Cloud
Dade City
Down and Out
During my winterizing I managed to lose my grip on a 12 inch clear flexible 3/4" tube which is now in our fresh water tank. We have a 2009 25-ft Flying Cloud. I assume it has to be removed. How labor intensive is removal? Has anyone else made this silly mistake. Will appreciate some good advice on this.
Dave
10-26-2011, 07:53 PM
1975 31' Sovereign
Opelika
, Alabama
why does it have to be removed? the tank is plastic, the tube is plastic, what is it going to do in there, rub a hole? poison somebody? i don't think so. forget about it. you would spend big bucks even trying to get it out. imho.
10-26-2011, 07:58 PM
Sioux Falls
, South Dakota
Some guy 25 years from now will post about finding a hose in a water tank . . . wondering what it's for.
10-26-2011, 08:12 PM
1974 Argosy 26
Morrill
, Nebraska
My question would be. What were you doing with the piece of plastic tubing in the first place?
10-26-2011, 08:14 PM
Retired.
, At Large
Many water tank filler hoses have a clear vinyl tube on the end that drops off at the most inconvenient moments. Like when it's inside the water filler neck.
10-26-2011, 09:00 PM
Oswego
The pump pickup tube fell off into the tank on my old SOB about 10 years before I sold it. I left it in there and it never caused a problem. Forget about it and move on.
11-01-2011, 06:25 AM
2016 30' Classic
Dade City
Thank you
Appreciate the help on this and taking the time to answer my questions.
Dave
11-01-2011, 07:36 AM
2015 27' Flying Cloud
2011 30' International
mooresburg
, Tennessee
I did the same thing, took a wire with a little hook in it and got it out. It was still in the fill tube. Good luck
11-01-2011, 08:32 AM
Holly Lake Ranch
What you need, my friend, is a plastic magnet. I believe those are on the shelf next to the bacon stretcher and the ambidextrous marshmallow roasting forks.
11-01-2011, 09:22 AM
2014 25' Flying Cloud
Cuddebackville
, New York
Nope, those were recalled.
11-30-2011, 11:23 AM
2004 34' Classic S/O
Stafford
, Virginia
11-30-2011, 11:54 AM
Holly Lake Ranch
Of course if you drop the mechanics claw down there, assuming its made of metal, it could rub a hole in your tank sometime over the next 15 years.... i vote in the leave well enough alone column
11-30-2011, 12:25 PM
Stafford
, Virginia
Hmmm, it is 36 inches long, if you dropped it, most of it would remain outside the tank!
11-30-2011, 03:06 PM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Join the Club
How many Airstreams have a 12 inch, clear-vinyl tube in their fresh water holding tanks?
Since we've all done it, or nearly done it, or will soon do it,
I guessing you just joined a very sizeable "intra-club" of the WBCCI.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
11-30-2011, 03:21 PM
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels
, Wisconsin
Me too
I can join, the 88 has one of those now. Or I should say has had one for 3 years or so!
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
11-30-2011, 03:40 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Down and Out
I joined this intra-club about 10 years ago with the first fill tube released into the Overlander's tank. Two years later, less than two weeks after having a new fresh water tank installed, the second fill tube was released into the new fresh water tank. Thus far, I haven't been able to manage to repeat this feat with my Minuet as the original water fill on the Minuet did not allow for the insertion of the tube, and the new fill that was installed when the plastic back of the original fill shattered has a device in the opening to prevent insertion of a tube.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
11-30-2011, 05:29 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Hose Clamp
All I can say is apply one for "protection"!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
11-30-2011, 05:37 PM
1972 29' Ambassador
grants pass
, Oregon
claw-leash
Now what you need is a "claw leash".
Tie it to your finger just in case.
1987 Avion 34X
