Old 01-22-2016, 01:31 PM   #1
1973 31' Sovereign
McDonough , Georgia
Do I remove this connector?
Do I need to remove the connector in the picture before I connect the toilet flange. The PO had the flange sitting in this connector with a wax seal between them. That just doesnt seem right.
Thank you,
Amy
acoursey is offline   Reply With Quote
Old 01-22-2016, 01:56 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The flange for the toilet must be matched to the toilet. RV toilets have bolted connections at the floor, at least those that I have experience with. I think you will need to remove that and replace it with one to match your toilet.
Maybe one like this?
Closet Toilet Flange MPT 600065 [600065] - $7.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
You will need the gasket for your specific toilet. It most likely will be a foam in the shape of a doughnut.
Look for the brand and model number of your toilet and use those to search for parts you need.
Alan
Old 01-22-2016, 02:17 PM   #3
1973 31' Sovereign
McDonough , Georgia
Hey Alan,
Thank you! Are you pretty sure that piece needs to be removed? I have tried to unscrew it but so far it wont budge.
Also, the flange I have is exactly like the one in the link you provided.
Thank you,
Amy
Old 01-22-2016, 03:49 PM   #4
Mission , Texas
My vote is that the foam ring goes on the thing in your photo ...
At least I remember something similar on ours when I worked on it.
nrgtrakr is offline   Reply With Quote
Old 01-22-2016, 04:36 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Thank you,
Amy
Attachment 256113
Hi,
The black threaded plastic piece you have in the picture is half of an old style two piece toilet flange. You must remove that piece to install a modern single piece toilet flange like AW Warn linked above.
From VTS you need a version B or J depending on the thickness of your sub-floor.
http://www.vintagetrailersupply.com/...-p/vts-736.htm
Have fun!
Lance
Top is offline   Reply With Quote
Old 01-23-2016, 11:59 AM   #6
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
How was the toilet attached to the floor or this flange?
It appears that the flange has been sealed with glue or epoxy. It is almost certainly threaded into the tank, but sometimes folks will do something silly like glue them in when they are stripped or the tank fitting cracks. (Usually from overtightening.)
The flange shown would use a foam seal as others have indicated, but it doesn't appear to have any holes for the bolts. I'm assuming that the toilet clamps down to it.
Anyway, let us know how toilet was attached and whether you are reusing toilet or not.
fwjumper is offline   Reply With Quote
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 02:57 PM
How to remove door to remove frig Silver84 Refrigerators 6 07-06-2015 02:32 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 11:23 AM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 01:48 PM
