Old 05-29-2014, 05:56 AM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by AtomicNo13 View Post
Try it once, you'll be a believer after a whiff of your effluent!
Lucky for me, mine doesn't smell.
2012 Dodge Durango Hemi/AWD
Old 05-29-2014, 06:10 AM   #16
Gainesville , Florida
Most parks require a hose, health regs. This is one reason flying j started to charge for dumping I heard. Too many just pulled up. Pulled the handle, and drove away without even trying to rinse everything down the hole. We have a county dump here and after the football games the ground around it is full of leftovers from those who do not want to get dirty themselves but do not mind leaving a mess for others. These people are football tail gators and their behavior will eventually lead to the dump being closed to all. Jim
Old 05-29-2014, 06:28 AM   #17
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Kind of related....
We boon docked at the WalMart in Butte Mt last year. I made coffee then stepped outside to walk the dogs. The owner of a giant, very new Moho decided to dump his black tank right there in the middle of the parking lot. I doubt he used a hose. The trail led right to his valve!
AtomicNo13 is online now   Reply With Quote
Old 05-29-2014, 06:51 AM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you need to buy a hose, buy a good quality hose. I've learned over the years that extra money spent to buy the heavier hose will pay dividends. The low cost ones will puncture on rocks, pieces of tree branches, etc.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-29-2014, 09:45 AM   #19
awetsch's Avatar
Albuquerque , New Mexico
Images: 48
Thanks everyone! I decided to purchase two of the Theford to Valterra Adapters and a Valterra Viper hose. Does anyone know the size of my black water tank? Are they typically the same size as the fresh water tank? Everything is still orginal in my trailer. Even the 200lb cast iron fresh water tank.
awetsch is offline   Reply With Quote
Old 05-29-2014, 12:14 PM   #20
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
No, the fresh water tank is larger...probably in the 20-30 gallon range in a early sixties trailer. The black tank is only going to be about 10 gallons. They figure, rightly so, that more fresh water is used as gray than black...in the sixties, it was okay to dump your gray on the ground and there is a bypass to do so.
Several years ago, we replaced the valves & repaired the tank on our (then) '64 GlobeTrotter. Here is a link to some pictures of what everything looked like under the belly pan:
Maxwell gets some TLC! Hope this helps ~
Being yours is a different year & model, the tank will be slightly different, but it still won't be 20-30 gallons...
Shari
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 08:12 PM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
