Old 10-29-2008, 07:22 PM   #1
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
custom or ABS tanks
I'm in research mode for tank options and am a little confused. Some of the stock sized aftermarket tanks (made of ABS I think) seem to be self supporting on the edge lip whereas custom tanks seem to need a sheet of 1/2" or 3/4" ply underneath. Is this the case?
truckasaurus is offline   Reply With Quote
Old 11-18-2008, 07:58 PM   #2
1999 19' Bambi
Fort Worth , Texas
who did you get your custom tanks from.
A.L. Mayfiel is offline   Reply With Quote
Old 11-22-2008, 02:53 PM   #3
That's not the case.
Fiberglass tanks have the lip, which is how the tank "pan" and top are joined together.
The fiberglass tanks are supported in the same manner as the ABS tanks.
Old 11-23-2008, 10:49 PM   #4
1960 33' Custom
Still very confused, this supplier says the tanks are ABS and with a supporting lip.
Holding Tanks - Icon Technologies Limited
But I am having trouble finding what I want in this guise so may go with polyethylene and support underneath. Quick question, how much slope does a grey tank need? And could I use the same product for both fresh and grey?
Old 02-04-2009, 10:03 AM   #5
vhord's Avatar
Images: 96
I'm still shopping for a gray tank(s). What did you decide to use?
vhord is offline   Reply With Quote
Old 02-04-2009, 10:20 AM   #6
Hey Vernon, I used this one, from PPL right there close to you in Houston, it's the model# H664:
RV Holding Tanks - 75 Sizes & Dimensions
My welder added in a removeable support member that bolts in and out for easy access in case I ever need to clean or repair it, and the "lip"
or "flange" on two of the other sides fits into the frame rails. It does hang below the belly by about 3 inches at its lowest. Here's my discussion of it on my thread, check post# 462:
http://www.airforums.com/forums/f109...-16692-33.html
Good luck!
Old 02-04-2009, 11:47 AM   #7
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Might want to take a look at what we did here:
http://www.airforums.com/forums/blog...tallation-144/
and here:
http://www.airforums.com/forums/blog...on-update-166/
Good Luck!
FLYNCLD is offline   Reply With Quote
Old 02-04-2009, 11:52 AM   #8
vhord's Avatar
Images: 96
Good luck!
I saw that one on their web page. I liked the 30 gal. capacity. But for whatever reason, I am still trying to keep everything above the belly pan if possible. Here is one that I am looking at. However it is smaller and it is extremely pricey for some reason. It is very close to the surface dimensions of yours. I could install two in tandom or isolate one for the galley and one for the shower but using two would be even more expensive.
ABS for the bath Argonaut20 All Argosy Trailers 4 04-30-2008 08:33 PM
Fresh Water Tanks: Polyethylene vs. ABS? DenverAaron Fresh Water Systems 9 01-29-2008 04:40 PM
Custom holding tanks Aerowood Plumbing - Systems & Fixtures 21 01-22-2008 09:15 AM
ABS vs PVC Gkiesel Waste Systems, Tanks & Totes 5 07-11-2007 06:56 AM
ABS Countertops Edie Cabinets, Counter Tops & Furnishings 1 03-23-2002 03:24 PM
