Custom Grey Water Tank - Sensor Questions
Hi all, I recently had a custom tank made for the back of my 31' 1969 Sov. It was build by INCA (very well, I must say), and is an exact replica of the original black water tank (spin fitting have been re-designed though). I will be using the new tank strictly for grey water and installing a composting toilet instead of a black water tank. Now for the questions. INCA has installed three sensors (see attached pic). I have read countless suggestions for what monitoring system I should install, but can't seem to find any information (including information provided by INCA) about what sort of connectors to use. The sensors have threaded (female) connections, as you might see from the picture. Is there an electrical connector I'm not familiar with that would screw into these, or are they designed for a an actual screw with a loop style electrical connector? The second question is; Is there ANY way I can hook these up to the original (working) panel at the front of my rig. I haven't removed any of the original wiring, only the original probe. My original tank had one sensor, whereas this new tank has three. I figure there must be at least one of you who have seen/used this type of sensor.
