Old 04-10-2016, 08:03 AM   #1
Gdickison's Avatar
1969 31' Sovereign
Orangeville , Ontario
Custom Grey Water Tank - Sensor Questions
Hi all, I recently had a custom tank made for the back of my 31' 1969 Sov. It was build by INCA (very well, I must say), and is an exact replica of the original black water tank (spin fitting have been re-designed though). I will be using the new tank strictly for grey water and installing a composting toilet instead of a black water tank. Now for the questions. INCA has installed three sensors (see attached pic). I have read countless suggestions for what monitoring system I should install, but can't seem to find any information (including information provided by INCA) about what sort of connectors to use. The sensors have threaded (female) connections, as you might see from the picture. Is there an electrical connector I'm not familiar with that would screw into these, or are they designed for a an actual screw with a loop style electrical connector? The second question is; Is there ANY way I can hook these up to the original (working) panel at the front of my rig. I haven't removed any of the original wiring, only the original probe. My original tank had one sensor, whereas this new tank has three. I figure there must be at least one of you who have seen/used this type of sensor.
Gdickison is offline   Reply With Quote
Old 04-10-2016, 08:21 AM   #2
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
It does just take a bolt with a wire connector that can Loop around the bolt when tightened. As far as the monitoring system you might have to update to a newer system to utilize the most out of the tank setup
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Grey water tank sensor Devoman Waste Systems, Tanks & Totes 13 10-20-2015 02:45 AM
Grey water sensor urnmor Waste Systems, Tanks & Totes 28 12-10-2014 07:17 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
Grey water sensor location djpierce Waste Systems, Tanks & Totes 0 10-08-2013 08:01 PM
Grey water sensor location 2011 27fb Mifair Waste Systems, Tanks & Totes 5 07-01-2012 12:21 AM
