Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-07-2009, 06:26 AM   #1
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Custom grey and black tank fabricators/suppliers and advice!!
Hi all,
I need to have a black tank made for one of my trailers that matches the rear curve, and I thought I'd see who everyone uses for custom fabrication?
Originally, I had planned to put the toilet on the floor, and run a 90 degree bend to the black tank under the floor. The toilet sits on the back corner, just outside the main frame rail, and the tank area hangs between the frame rails in the middle.
After looking at numerous plans, it seems like the best way is to drop directly into the tank, though so now I'm thinking about something above the floor.
Any advice would be appreciated! Thanks!
JP
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 08-07-2009, 09:03 AM   #2
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
YES, You want it to drop straight into the tank. You won't have enough water to run it through a pipe unless your hooked up, and then you black tank will fill up fast.
You could try your local RV dealer. some of them have people who make custom tanks, but it won't be cheap. Probably over $500 for a curved one... And it will have to be fiberglass is my guess...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-07-2009, 09:05 AM   #3
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Images: 40
Airstream Registry
When I needed a fresh water tank, I contacted All-Rite.com. They wanted a very detailed drawing with the dimensions along with the exact placement and diameter of the inlet & outlet holes. I am very happy with it. I've also heard folks use Inca Plastics but don't know about the results.
Good luck on your decision.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 08-07-2009, 09:14 AM   #4
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
That was quick! Thanks! I'll send them both a note and see what they want for it.
JP
Old 08-07-2009, 09:31 AM   #5
Profile:  1963 26' Overlander
Airstream Registry
You might consider having a metal fabricator make one for you out of stainless. Since I know you like the look of exposed metal, you wouldn't even need to cover it with anything at all, unless you wanted to.
I know Rob Baker has a guy up in his neck of the woods who made his freshwater tanks for him out of stainless, and his buddy John (RoverOwner here on the Forums) had the same guy fabricate an above-the-floor black tank for his '61 Ambassador out of stainless as well.
utee94 is online now   Reply With Quote
Old 08-07-2009, 10:39 AM   #6
SilverHoot's Avatar
Profile:  1967 24' Tradewind
Redding , California
Airstream Registry
Wow! I love those stainless tanks. If mine were going above the floor I'd definitely check into that.
SilverHoot is offline   Reply With Quote
Old 08-07-2009, 10:53 AM   #7
flyfshr's Avatar
Phoenix , Arizona
Images: 40
Airstream Registry
Are the stainless tanks strong enough on top to support a toilet, the water inside plus the person's body weight? Seems it would really need to be supported on the inside if you wanted clean, unobtrusive lines on the top of the tank. I thought about stainless when I redid my black tank but I'm 6'4" and at the time was 295 pounds. The thought of a stainless tank was a short-lived one.
FF
WBCCI/VAC #2699
Air #10
Old 08-07-2009, 12:21 PM   #8
Airstream Registry
That I don't know, Brad.
I think John is planning on building a surround for it, and I don't know if his intent is for that surround to bear some of the weight of the person using the turlet.
Of course, you could always have it built from plastic or fiberglass, and shroud it with wood...
Old 08-07-2009, 01:53 PM   #9
Profile:  1963 24' Tradewind
Cape Coral , Florida
Our plan calls for moving the bath to center curbside and putting the potable water tank under the floor just ahead of the axle. The grey tank is just behind the axle. We got our potable and grey tanks from pplmotorhomes and our blacktank/showerpan combo, which is above the floor as a wet bath, from pellandent.com. plastic-mart.com and tank-depot.com have very extensive inventories.
dieseleagle is offline   Reply With Quote
Old 08-07-2009, 02:26 PM   #10
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
norcalbambi had something in his thread about making custom tanks from sheet foam and fiberglass. Maybe useful in this case? I think it's in his flying cloud thread.
Rich
See my blog: http://1964airstreamsafari.blogspot.com/
VIKING is online now   Reply With Quote
Old 08-07-2009, 04:47 PM   #11
pbearsailor's Avatar
Profile:  1957 22' Caravanner
Blaine , Washington
Airstream Registry
Rich
Yes, that's where it is. I'm planning to do it that way for my black tank, but I won't be getting around to it for a few more months.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is online now   Reply With Quote
Old 08-11-2009, 05:35 PM   #12
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
ok. calling tomorrow to get a quote on a stainless tank!! I did the math, and I should be able to get a little over 10 gallons of stinky water above the floor. a gallon is 231 ci.
did I need to get a stainless toilet mount? or just use the plastic ones with a gasket?
JP
Old 08-11-2009, 08:25 PM   #13
Airstream Registry
JP
I'm not certain, I've asked Rob's buddy John to weigh in with his thoughts on this, hopefully he'll check this thread tomorrow and give you some insights.
Old 08-15-2009, 12:31 PM   #14
Mouse Nest Hunter
RoverOwner's Avatar
Profile:  1961 28' Ambassador
Sherburne , New York
That is my tank that Marcus posted pictures of.
The tank is very heavy duty. It would support all the weight you could put on it. The price you pay for such a sturdy tank, however, is lots of weight. I would guess the tank weighs around 80 pounds. I had it built by Daryl at Pharsalia Metal Fabrication in Pharsalia, NY. He is local to me, otherwise I'm sure shipping would be quite expensive. I gave Daryl my original fiberglass tank to copy, and he put the inlet, outlet, and vent holes in the same spots using stainless fittings. You then use plastic fittings which screw directly into your tank.
Cost of the tank was $600. A little bit pricey, but I will never have to deal with any issues in the future with the tank. This was very important top me, as to get the tank back out, the vanity and wardrobe must be removed first.
I can get Daryl's contact information for you, if you like.
Best of luck
John
www.1961airstream.blogspot.com
TAC NY-2
RoverOwner is offline   Reply With Quote
custom built grey tank on my 73 safari? aaumpine Waste Systems, Tanks & Totes 11 01-10-2009 07:42 PM
Combination Grey and Black Tank Idea! A-Merry-Can Waste Systems, Tanks & Totes 8 05-05-2007 09:52 AM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 08:15 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
CCD Grey/Black Tank Combo LuvSub 2003 International CCD 5 05-11-2003 08:04 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vBulletin Plugins by Drive Thru Online, Inc.
