Old 08-17-2009, 12:02 PM   #29
I don't know what your plans are Norm, but in my back-half renovation, I have removed quite a bit of weight. By replacing the cast iron/porcelain sink with a stainless one, and using frame construction rather than plywood construction for the vanity, I've probably knocked off 30-40 lbs in the bathroom alone. I've done the same with the beds, and probably removed 10-15 lbs there as well.
If you're careful, you can probably absorb the weight of the stainless tank and lose it elsewhere.
Old 08-17-2009, 12:43 PM   #30
nmbosa's Avatar
Nowhere , Washington
I'll have to see what I can do on the weight issue. My plan was to pretty much stick to the original as closely as possible and there really isn't much back there right now other than the toilet, black tank, small vaniety and tub. The 59's only have one wardrobe in the back and the vaniety is much smaller than in the later Overlanders. My best bet for weight reduction in the bath is the sink, but it's only about 12"x12"x6" deep so I'm not going to get a huge amount of weight relief unless I replace it with plastic.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 08-17-2009, 12:51 PM   #31
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We built a marine plywood "box" around the tank - supported on the walls with angle clips. So we have the tank, then the wood support then the thin stainless steel...check out posts #346 & 347 for pics. It's really solid and not going anywhere! We figured that while the plastic would support the weight, deflecting over time could compromise and eventually crack it. We never really considered going with a stainless tank heavy-duty enough not to deflect...what gauge are you going with JP?
Shari
Old 08-12-2010, 04:10 PM   #32
nmbosa's Avatar
Well, a year later and I'm finally ordering my black tank. Unfortunately, the quote I just got for a plastic tank is $1,240 plus packing and shiping of another $150.00. . Time to find a local sheet metal fabricator.
Norm and Mary
Old 10-13-2010, 07:55 PM   #33
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Check Ronco
I recently purchased 2 tanks from Ronco.Uwe Salwender had suggested them.They were great to work with and able to advise me on tanks in their stock that would work for my application.Not sure about curved ,but I am sure they do custom .I was able to get a great price off list! These guys were great!They are in Ca. ronco-plastics.com
bwaysteve is offline   Reply With Quote
Old 10-14-2010, 08:02 PM   #34
1969 18' Caravel
portland , Oregon
Andy at Inland RV had an exact match fiberglass blackwater tank for my 69 Caravel. It also curves for the back corner of the trailer. I was not only surprised that they had one, but the tank was somewhere around $300 - much cheaper than I expected to pay to try and have one made.
scottwtalley is offline   Reply With Quote
Old 10-14-2010, 08:38 PM   #35
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Originally Posted by A-Merry-Can View Post
Hi all,
I need to have a black tank made for one of my trailers that matches the rear curve, and I thought I'd see who everyone uses for custom fabrication?
Originally, I had planned to put the toilet on the floor, and run a 90 degree bend to the black tank under the floor. The toilet sits on the back corner, just outside the main frame rail, and the tank area hangs between the frame rails in the middle.
After looking at numerous plans, it seems like the best way is to drop directly into the tank, though so now I'm thinking about something above the floor.
Any advice would be appreciated! Thanks!
JP
I recently got a bid from All-rite for a curved on top of the floor black tank for my 1960 18' trailer and it was over $1,000! Seemed a bit pricey to me.
lucymcdog is offline   Reply With Quote
Old 10-15-2010, 08:41 PM   #36
Have any of you considered blocking those curves into lines, and just approximating as close as you can? I'm guessing that has to be significantly easier than fabricating the curves. You'll lose a bit of capacity, but compared to the price?
You've probably already considered this, I'm just sayin...
Old 10-16-2010, 07:30 AM   #37
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Actually, that's what I decided to do. I figured out how wide and long I could make it without going into the curve and was able to come up with a pretty decent sized tank (18 gallons) for around $150.00 from Tank Depot. The potty can still sit where it was originally - I just have to reposition the sewer outlet somewhat. MUCH less expensive than having a tank custom made!
Old 06-20-2017, 04:08 AM   #38
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Does anyone have a picture of how your valve goes thru the belly pan?
It seems there is an extra 1.5" in length on the new valterra valve to deal with that was not there on the old Thetford valve.
Dingo Girl is offline   Reply With Quote
Old 07-06-2017, 06:37 AM   #39
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I'm going with a separate grey tank with its own drain valve on the curbside & and black tank drain on the street side.
This eliminates having to have a bunch of "stick out" on the bottom of the camper..
Can't come up with a better way.
custom built grey tank on my 73 safari? aaumpine Waste Systems, Tanks & Totes 11 01-10-2009 06:42 PM
Combination Grey and Black Tank Idea! A-Merry-Can Waste Systems, Tanks & Totes 8 05-05-2007 08:52 AM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 07:15 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
CCD Grey/Black Tank Combo LuvSub 2002 - 2005 International 5 05-11-2003 07:04 PM
