Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Prev Previous Post   Next Post Next
Old 05-06-2009, 09:35 PM   #1
Profile:  2009 25' FB International
East Hampton , New York
Creating a home "dump station"
HI - I have a 19' international (new to RV'ing) and have set-up a nice pad beside my house with 30amp elec, connection to my satellite dish on the roof, fresh h20 and the last item is to create a sewer connection. I was thinking about getting one of these (Portable RV Waste Pump > Toilet Waste Pumps > RV/Caravan > Flojet - ITT) which I've seen advertised (it macerates and send the effluent out a standard garden hose) then asking my plumber to run a Y off one of the existing waste stack pipes in my basement (conveniently close to the exterior wall where I'm parking the RV) with 2" pipe up and out the side of my house near the RV with a screw cap on the cover. Then, when I want to dump, I can connect the macerating pump to the RV, put the other end into the 2" pipe coming out of the house and "let 'er rip". The pipe into the house will be higher than my waste outlet on the RV (by about 36 inches) but the flotjet pump is advertised to be able to pump up to 25 feet away and up some height. This solution sounds like it will work but I'm not certain. Has anybody done this? Did it work? Other suggestiosn?
zevrosenthal is offline   Reply With Quote
Speaking of AC ??"Is my motor home haunted ?" myfirstrv Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-03-2008 07:07 AM
WBCCI's current plans to rebadge an SOB Class "A" motor home Melody Ranch WBCCI Forum 1 06-04-2007 09:02 PM
Most scenic "dump stations" jordandvm Off Topic Forum 9 06-20-2005 02:29 PM
454 "Factory Manifolds" free to a good home swebster Parts Archive 2 03-24-2004 08:58 AM
