Old 08-03-2019, 05:28 AM   #1
Roadhoop's Avatar
2016 25' Flying Cloud
Fort Worth , Texas
Create long sewer hose
At home I can hook my trailer up to my septic system. Need 100 feet of sewer hose. Anybody build their own or have a ready made solution?
I know the concerns about using home septic system. Asking about a solution for 100 foot hose.
Roadhoop is offline   Reply With Quote
Old 08-03-2019, 05:37 AM   #2
Kevin245's Avatar
Have you looked at Sewer Solution?
https://www.valterra.com/product/sew...-system-boxed/
Eleanor Roosevelt
Old 08-03-2019, 05:40 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I concur although 100 ft might be a reach. I have used almost 50 ft with PVC pipe at home to my cleanout plug. Plenty of water pressure for that.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-03-2019, 05:58 AM   #4
Gainesville , Florida
Use p!asticpipe the correct diameter with connectors. 3 inch i tnink. Sewer pipe.
Old 08-03-2019, 06:11 AM   #5
batman's Avatar
1964 22' Safari
modesto , California
Go to the hardware store and get 3" ABS pipe, usually 10 or 20 foot lengths, Couplers , bushings, and any other 45's or 90s', etc.
Get on line and order the RV sewer hose to ABS adapters from Valtera or Camco, etc.
https://www.amazon.com/s?k=rv+sewer+...f=nb_sb_noss_2
Lay it all out, glue it and screw it all together. done. Have a cold one and try it out.
-Dennis
batman is offline   Reply With Quote
Old 08-03-2019, 06:56 AM   #6
kpm
2018 25' International
Mound , Minnesota
3" PVC pipe should do nicely. Be sure to establish a gradient between 1/4" and 3" per foot. Less than that leaves you open to clogging; more than that may allow the liquid to drain without the solids
kpm is offline   Reply With Quote
Old 08-03-2019, 09:22 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
You could also consider having a professional install the correct "dump connection" that is convenient to where you park your AS
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 08-03-2019, 10:24 AM   #8
WDCgator
wdcgator's Avatar
2018 16' Sport
Clearwater , Florida
Sewer Solution
Go to Amazon and get Sewer Solution. You can use a 100’ hose
wdcgator is offline   Reply With Quote
Old 08-03-2019, 10:40 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I go over 100' to the sewer cleanout at home. I use the Sewer Solution with a combination of Sewer Solution flexible hose and 1.5" PVC. I have been using this for over ten years and it works perfectly. I also use the Sewer Solution on the road and have been using it for thirteen years.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 08-03-2019, 12:10 PM   #10
Mollysdad's Avatar
Since it's your home, do it right.
Use 3" PVC with clean outs buried just as if it was from a house.
Leave a capped entry near where you park the trailer.
Why bother with 100' of hose?
Old 08-03-2019, 12:22 PM   #11
2007 27' Safari FB SE
Forest Grove , Oregon
One reason to use a sewer solution, or Flojet system is when you have a situation where the trailer is parked level with or even slightly below the cleanout for the house...meaning putting in dedicated lines with the proper pitch is not possible without completely rebuilding the septic system. However using a system that pumps the fluids does move it to the cleanout in fine fashion.
bweybright is offline   Reply With Quote
Old 08-03-2019, 02:02 PM   #12
Kevin245's Avatar
The 3-inch pipe concept will work if you are able to achieve the proper slope from the RV to the septic tank/line. The sewer solution works where there is no slope, or there is a slightly up hill grade. The Sewer Solution is as close to “ready made” as one can reasonably expect. Outside of the kit purchase, all you need are some lengths of 1-inch bell end pvc, or standard pvc and couplings. We have one in use on a full time hookup to a septic tank line. Our 1-inch pvc is buried and tee’s into the top of the 4-inch line.
Just my $0.02.
Eleanor Roosevelt
Old 08-03-2019, 10:36 PM   #13
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Sewer Solution is the answer to your problem. We had one for several years, at a couple places where we set up, we've pumped over 100 feet, with up to a 2 foot rise over that 100 feet. I use PVC thin wall pipe, and cut it into 4 foot sections with couplers that connect each piece. a 3/4" conduit will connect to standard hose that comes with the Sewer Solutions to the PVC pipe.
It' a great product.....for whatever it's worth.
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-14-2019, 10:42 AM   #14
1990 25' Excella
Cherryfield , Maine
create a long sewer hose
I did the PVC pipe and was happy as a clam. Until the code enforcement officer visited and advised it was a code violation to have the pipe above ground!
jim wade is offline   Reply With Quote
Valterra 10-Foot Sewer Solution Kit, Macerator Universal Sewer Hose Rpatrick16 On The Road... 16 04-09-2019 11:11 AM
Fresh Water Hose and Sewer Hose Length Dilemma bigcountry Fresh Water Systems 40 04-08-2019 12:23 PM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
Sewer hose — how long is long enough? WhereStream Waste Systems, Tanks & Totes 41 10-17-2017 05:58 PM
