Old 06-30-2008, 09:17 PM   #1
Duff23's Avatar
1976 Argosy 26
Oxford , Connecticut
Could there be an Argosy with NO Black Water Tank?
Hi all. I'm considering the purchase of a 1981 Argosy 22' (long distance, sight unseen (except for pictures) type of purchase) but the current owners say that there is no black water tank. Could this be? I really like the trailer and its small size but don't think I can accept this deficiency. Is it possible for me to install the black water system myself? Is it an enormous task or reasonable enough for a handy man? Any advice would be appreciated. Duff
Duff23 is offline   Reply With Quote
Old 06-30-2008, 09:27 PM   #2
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
mine has one...
Duff,
My '76 24' has a black water and grey water tank. Seems unlikely that a later model wouldn't have one. The tanks are a bit small Grey=14 gal and the Black at about 10. Still the black water lasts four to five days when dry camping but the grey water only lasts a day. We're not very good at being careful with water utilization. The tote along 22 gallon solves the problem.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 06-30-2008, 09:32 PM   #3
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Hmmmm,
Our 1977 Argosy Minuet 6.0 Metre has a black water tank - 10 or 12 gallons as I recall. I would bet the "newer" model you are interested in would have at least the same.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 06-30-2008, 09:38 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Any photographs should suggest what is going on. Argosy black water tanks are all above the floor. If there's a shorty commode sitting on top of about 10" of enclosed cabinetry, I'd think that may be near original; ie, the black water tank is in the cabinetry above the floor.
5 meter Langford Nahanni
Old 06-30-2008, 09:45 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Argosys were only made from 1972 - 1979 then again 88-89 period. There were no 1981 Argosys. Maybe you are looking at another brand.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-01-2008, 12:11 AM   #6
Darol Ingalls's Avatar
Shacksman's right. There were no '81 Argosys. and the newer ones were all larger and square. I suspect your seller doesn't know what he has. Ask for photos of the bath and check to see if the toilet sits above the floor level as suggested in a prior response. Also, ask for the information of the mfg's plate. It should have the serial number and date of mfg. All Argosys made from '72 and on had black water tanks and all made from '74 and on had black and grey water tanks. Yes, they were small, but at least they were there. I think you need better information before making the trip. You should also be aware that the 22' Argosy REAR DOOR models had some major towing issues due to the placement of the axels so near the center of balance of the trailer. Darol
Darol Ingalls is offline   Reply With Quote
Old 07-01-2008, 08:33 AM   #7
Duff23's Avatar
1976 Argosy 26
Here's a picture of the streetside. If it were plumbed with a BW tank, wouldn't we clearly see some plumbing just forward of the rear bumper in this photo? The owner's say they were told by the PO's that it came from the factory without a BW tank. I just find it odd that someone would custom order a coach w/o one.
Old 07-01-2008, 08:46 AM   #8
Pfredd's Avatar
1978 Argosy Minuet 6.7 Metre
1977 31' Sovereign
1977 Argosy 24
Cincinnati , Ohio
The plumbing connection for my '78 Minuet 6.7 Meter is actually underneath the trailer, behind the rear wheel. You do not normally see any of the plumbing for it. The valve pulls are located in the bumper compartment. Both tanks are above floor level, and the shower dumps directly into the drain line, bypassing the grey tank.
Maybe that is what this one has.
My '77 Argosy 24 has the dump connection in the side of the bumper compartment. The black tank valve pull is in the bumper compartment. The gray tank valve pull is on the side near the bumper. The black tank is above the floor, the gray below with the shower draining into the gray tank.
Dave
Visit my web site for Airstream Photos, Projects & Blog
Pfredd is offline   Reply With Quote
Old 07-01-2008, 09:05 AM   #9
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hard to say from this pic, but I THINK I see the waste plumbing connector just forward of the bumper.
I was about to say how cherry it looked... then I looked again. The side panel by the water heater is one big patch... see the non-standard (and looks like it has a gap too) seam just aft the waterheater door? Paint match is just a tad off too.... I think those brown stripes (which is not orginal.. but looks ok) are painted to camo the patch.
The whole trailer looks to have been painted prior to the patch... notice the window frames and upper light bezels are in raw aluminum... that's not stock. A body paint isn't so bad (the Argosy paint was known to flake off)... but that patch and the bungled lower trim infront and just of the rear of the waterheater seems to indicate something happened in that location. Overall, it looks nice from this angle though...
Any other pics?
Has a newer AC unit on top, judging by the rear lights.. I'd say a 78.
Interior pics would really let us know what's happening in the bathroom.
Marc
Old 07-01-2008, 09:50 AM   #10
Duff23's Avatar
1976 Argosy 26
Wow! I'm so glad you noticed that. I saw the discoloration and odd looking panel but don't have the experience to know with certainty that it wasn't stock. I still don't understand what you're saying about the upper light bezels though.
Here are some more pix. Looks like there's also a little patchwork under the left tail light too. Toilet is up on the step but those are just standard provisions right?...there's no guarantee that there's a tank under there. The current owners reupholstered the interior.
Aside from the questionable exterior panel it looks clean. They're listing it as a 1981 model, but Shacksman is already discounting that. If their title says 1981, what else could it be? Any ideas?
Thanks, Duff
ID:	63056   Click image for larger version
ID:	63058   Click image for larger version
Old 07-01-2008, 10:25 AM   #11
Pfredd's Avatar
1977 31' Sovereign
1977 Argosy 24
Cincinnati , Ohio
Is there a serial number tag on the front of it? If so, what is the info on it?
Old 07-01-2008, 11:00 AM   #12
Thanks, Duff
Duff, from the one photo down the length of the trailer aisle and looking aft into the bathroom, do you see how the toilet is sitting up on a "step" or "riser?" That is what it looks like when the black tank is above floor level. I haven't been in the trailer so I obviously can't guarantee there is a black tank, but from that picture, this trailer appears to have one.
Old 07-01-2008, 11:06 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That small cabinet under the toilet is where our black tank was located in our Argosy. Dump valve is in the bumper compartment, and the slinky hookup is centered under the valve, facing directly down. You would not normally see the hookup. Also, from the taillight and binnacle configuration, the trailer is at best a 1974 model.
Old 07-01-2008, 01:01 PM   #14
Duff, Well, since this is not a rear door model, it will tow beautifully. The patch on the roadside is bothersome. Could it be that there was a major accident in the late 70's/early 80's, insurance totaled it, repairs made and a salvage title issued in '81? Can't make out the state on the license plates and rules about titles change from state to state, but it's something you should check. Interior looks good! You should be able to see the black tank by opening the closet door next to the toilet and looking back under the toilet shelf. Also, the slide valve is in the bumper compartment. The grey tank slide valve is just in front of the bumper on the roadside. Both tanks drain through the same exit which is just inside the curve of the rear bumper on the road side. The trailer has definately been repainted because the trim is not original to any year of Argosy. Darol
73 Argosy Black Water Tank Valve Problem 73Argosy20 Waste Systems, Tanks & Totes 2 09-14-2007 06:46 PM
need new black water tank KHarris Waste Systems, Tanks & Totes 4 09-24-2006 08:34 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
