Old 05-01-2011, 07:52 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Convert or Replace Thetford Waste Valves
I'm having consistent problems with my 94/34 Classic Limited waste valves. The black valve will not close tight. Have cleaned it a couple times with temporary success. Need advice on replacing or converting them. Also, Would like to premanently convert the outside waste connector to accept Valtera. Any suggestions on that? DH.
Emh142 is offline   Reply With Quote
Old 05-14-2011, 11:35 AM   #2
1992 29' Excella
DFW , Texas
Originally Posted by Emh142 View Post
..... Also, Would like to premanently convert the outside waste connector to accept Valtera. Any suggestions on that? DH.
I just made the conversion. A reciprocating saw was almost impossible to use because of the clearance between the tank valve handles. Same story for a hacksaw. I ended up just using the blade by itself. Cut slow and as straight as you can. The Valtera end fitting only had about 5/8 inch for the glue joint. Use plenty of PVC cleaner and one of the PVC glues suitable for wet conditions and you should do fine. I use a Sewer Solution hookup and after the conversion, it fits so much better without having to use a Thetford to Valteria adapter. The added benefit is that I can now buy my stinky slinky connection parts at Walley World :-)
TxToaster is offline   Reply With Quote
Old 05-15-2011, 07:05 PM   #3
PopHetzler
Emh142's Avatar
Troy , Ohio
thanks for the tips. I pulled the Thetford valves out and cleaned them again and replaced all the seals. I'll give the replacement a try as soon as the weather breaks.
See you down the road. DH.
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 12:18 PM
Threaded waste valve... mnmhays Waste Systems, Tanks & Totes 4 03-29-2012 05:45 AM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
To replace the pump or not? MTsafari Water Heaters, Filters & Pumps 8 04-04-2011 07:20 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
