Old 08-13-2016, 02:56 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Commando Black Tank Cleaner
New product on the market. Advertises that it will get bad sensors working. Has anyone given it a try?
https://www.amazon.com/gp/product/B0...A3LIAZP5IVN5FN
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 08-13-2016, 04:03 PM   #3
AWCHIEF's Avatar
Images: 33
I think I keep my tank clean as clean as possible. My issue is with the sensors. They have not worked properly in my trailer since I bought it. If this actually works as advertised it could save a lot of money over replacing the sensor system.
MICHAEL
Old 02-09-2017, 11:39 PM   #4
Hugh
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
AwChief- I had a 2007 25 Safari LS SE that had the same kind of sensors as your 23. The sensors worked Ok for a while and tried recalibration. This helped for a while. However I found that the sensors were very sensitive to battery condition and would show a full fresh water tank when plugged into shore power then would drop to 3/4 when disconnected. Also I had a tank flush with my SE that you might not have had with the LS. But it was marginal at best. What I did for black water tank was to buy a Toilet Wand from Camping World it's a high pressure 4 jet device that you place down in the toilet throat in an empty tank with the valve open. It does an OK job. A little messy but OK. Not sure of the price but somewhere between 20-30 bucks
zapper is offline   Reply With Quote
Black Tank Sensor Cleaner Worked - What is it? Wayward Waste Systems, Tanks & Totes 3 11-12-2014 05:55 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Extreme Simple Green Aircraft Cleaner and black streaks on Argosy whitefawn Cleaning, Stripping & Polishing 0 07-28-2012 08:52 PM
Central Vacuum Cleaner Snadi Nu-Tone Appliances & Central Vac System 8 06-23-2005 06:29 AM
Carb cleaner Bill Resseau Mechanics Corner - Engines, Transmission & More... 4 04-30-2003 10:17 AM
