Old 05-09-2003, 06:33 PM   #1
coconut oil lubricant for drains
The Blue Beret recently recommended coconut oil for the black and gray holding units to lubricate the open and shut valves. Where can I buy it?Local Walmart does not carry this product.
murphy is offline   Reply With Quote
Old 05-09-2003, 07:38 PM   #2
Chas's Avatar
Images: 22
I saw that also. Wondered why Mallwart would carry coconut oil, who uses it? Isn't it one of the tropical oils which are bad for ones health? My guess would be some sort of restaurant food supplier. Maybe it is a tanning product?
Guess you could just drink a lot of pina coladas and get a similar effect.
Chas
Chas is offline   Reply With Quote
Old 05-09-2003, 07:56 PM   #3
Just to make things clear, you were talking about "Potassium Cocoate".
If this is the case (and it is), I have the feeling that WalMart was unloading it a few years ago. I bougth a few bottles of the stuff on clearance. Just because it was about 50cts each.
Camco 800-334-2004 X 155
For the price, we tried it.
Do like Chas said, spend your money on pina colada.
femuse is offline   Reply With Quote
Old 05-10-2003, 04:03 PM   #4
1975 31' Sovereign
Drasco , Arkansas
Send a message via AIM to BILLY SPIER Send a message via Yahoo to BILLY SPIER
holding tank valves
WHAT ELSE CAN BE USED TO LUBRICATE THE VALVES? I HAVE ONE THAT STICKS IN THE BLACK WATER TANK.
THANKS BILLY
bdbluegrass
BILLY SPIER is offline   Reply With Quote
Old 05-10-2003, 05:03 PM   #5
My guess is, if your valve is original 1976, no amount of lubrication will make it work smoothly.
We replaced the one in our 1974: the rubber-like seal was stuck to sliding part & was pulled out of its seat. We could have replaced the seal, but it nearly costs the same as the whole valve. For the work of taking the valve out.....
Old 05-11-2003, 05:01 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Re: holding tank valves
THANKS BILLY
billy,
i used silicone grease applied directly to the seal and gate when i had my valve out to repair a leak.
works well, it slides very easy now.
the only drawback is that you must have the valve out of the trailer to do this.
and as femuse pointed out, you might as well get a new one at that point.
the cost of tossing some cocconut oil in the tank is minimal, what the heck, give it a try. maybe it would work.
john
Old 05-11-2003, 04:45 PM   #7
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Just to be clear...
We were talking about COCONUT OIL, pure and simple. The stuff that is BAD for your health. This is specifically what Dave Shumann (A/S Director of Warranty) recommended.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 05-11-2003, 04:58 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
In all the years we've had trailers, we've never had a problem with the valve. We winterize it, dewinterize it, use it, flush it and each year we had no issues.
I suppose perhaps I have something to look forward to??
Eric
Old 05-12-2003, 07:33 AM   #9
CatandMe's Avatar
We had a sticky black water valve too. We tried various types of lubricants. Nothing worked. We had to change the valve.
Cathy & Me, taking it easy now....
Ready to travel and see the USA
CatandMe is offline   Reply With Quote
Old 05-12-2003, 08:01 AM   #10
1975 31' Sovereign
Eau Claire , Wisconsin
sticky valve
RV antifreeze seemed to free my stuck valves.
Brouck
Brouck
Wherever you go... there you are!
bhsl8 is offline   Reply With Quote
Oil Filter Study ViewRVs Mechanics Corner - Engines, Transmission & More... 32 03-11-2010 06:26 PM
Synthetic oil viscosities for heavy-duty towing ipso_facto Tow Vehicles 1 01-16-2004 07:04 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
No oil pressure! Stefrobrts Mechanics Corner - Engines, Transmission & More... 3 11-06-2003 08:47 PM
Tag Axle Oil Level? swebster Airstream Motorhome Forums 9 08-25-2003 05:01 AM
