Old 02-06-2015, 11:29 AM   #1
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
clear connector
Is there a clear connector to fit the Thetford hookup? I would like to get a short one to make sure my tanks are emptying ok, but can't find one. Do I need to switch to Valterra connectors?
rod
rbs is offline   Reply With Quote
Old 02-16-2015, 08:46 PM   #2
1969 29' Ambassador
Hartselle , Alabama
I think Valera makes an adapter for the white Thetford valves. I found one at my local rv store.
dave69 is offline   Reply With Quote
Old 02-16-2015, 09:13 PM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
rod
I bought a clear Valterra and adapter to go from a Thetford to the Valterra.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 02-16-2015, 10:21 PM   #4
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Yep they make 90*, 45*, short straight, long straight, even models to reverse flush the tank.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-17-2015, 06:33 AM   #5
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
would you remember where you purchased or can purchase one?
Old 02-17-2015, 06:53 AM   #6
1969 29' Ambassador
Hartselle , Alabama
This is the Valterra adapter you will need to attach modern hoses and clear chambers to the white Thetford valves.
Old 02-17-2015, 08:08 AM   #7
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Bottom line: Nobody has seen a clear Thetford connector. Use a Thetford to valterra adapter first in line, then you can use whatever Valterra stuff you want.
Old 02-17-2015, 08:51 AM   #8
1974 Argosy 28
Images: 37
Any RV dealership should have one. Camping World for sure.
Old 02-17-2015, 10:25 AM   #9
Glenritas's Avatar
1969 25' Tradewind
My local RV store.
Camping World also has the clear fittings.
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 02-17-2015, 10:29 AM   #10
mefly2's Avatar
2015 25' FB Eddie Bauer
Or ...Wally ...
Old 04-13-2015, 10:06 AM   #11
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Wally
Originally Posted by mefly2 View Post
Or ...Wally ...
What is "Wally"?
I was aware that a person could purchase a Thetford to Valetera adapter, change the Thetford connector on the stinky slinky to a Valtera, but would like to not have anymore connections than possible (hate leaks) hence the search for a Thetford clear connector. I do have the setup with an adapter to use the Sewer Solution, but it is assemble to not take apart to eliminate the ever present leaking.
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 09:12 PM
nine pin connector driftwood Electrical - Systems, Generators, Batteries & Solar 2 09-24-2003 12:45 PM
Connector Diagram at AIRSTREAM smily Brakes & Brake Controllers 0 09-10-2002 09:02 AM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 01:48 PM
