03-20-2019, 12:58 PM
2003 26' Land Yacht 26
Portland
, Oregon
Chemical cleaners for holding tanks, 2003 Land Yacht
Hello,
I have a 2003 Class A Land Yacht, 26'. We bought it used with very low mileage and usage.
The grey water tank seems to be lined with organic material. After an initial rush of water it will drain slowly for what seems like forever.
Can I use a "Mr. Plumber" type cleaning product to help clean the inside of the tank? My online research has returned mixed opinions so I am now asking the experts.
Thank you for your help.
03-20-2019, 01:13 PM
2007 22' International CCD
Corona
Try a shot of Clorox or other chlorine bleach at about 1/2 cup per ten gallons capacity, fill the tank to near the top and let it soak for several hours. Could also drive around to slosh the solution around a bit. Then drain. Be careful not to splash on clothing. See if that helps.
03-22-2019, 12:29 PM
Portland
, Oregon
Rich,
Will do. We will be traveling a bit in April and I will apply your suggestion as we go.
Thank you for taking the time to reply.
Best regards,
03-22-2019, 12:35 PM
2018 27' Globetrotter
Apollo Beach
I would use a product called Bio-Clean. This stuff is expensive but works without damaging pvc pipes etc. We sold it at my plumbing company for $49 too. Maybe there are similar products for less, but I know this one works. Follow the instructions on the label. https://www.amazon.com/Bio-clean-Dra...gateway&sr=8-3
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
03-22-2019, 12:40 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
A product like "Mr. Plumber" would likely be OK on the plastic parts of the system, but could adversely affect any rubber, such as the seals in the drain valves. I use an enzyme holding tank treatment, but if you have a calcified scale on the tank then you might have to use vinegar to dissolve it.
Ray B.
03-22-2019, 12:52 PM
Apollo Beach
Same kind of stuff as Bioclean "enzyme". Quote from Bioclean site:
"Bio-Clean is a special combination of natural bacteria and enzymes formulated specifically to digest dead organic waste found in your plumbing system. Bio-Clean will remove the grease, hair, soap scum, food particles, paper and cotton that are plugging your drain lines.
Bio-Clean will not digest or have any effect on inorganic materials such as plastic pipe. Bio-Clean will not produce heat, fumes or boiling like dangerous chemicals do.
Bio-Clean is completely safe for people, plumbing systems, septic tanks and the environment."
03-22-2019, 01:35 PM
Overland Adventurer
2009 34' Panamerica
Telluride
A heavy dose of tri sodium phosphate allowed to soak for several days will soften the mess. Slosh by driving a while, then dump.
Lather rinse repeat and you'll be good as new!
03-22-2019, 01:43 PM
2002 25' Safari
Dewey
The grey tanks in my Airstreams had the valve on the side of tank. As the tank emptied the flow would decrease. When almost empty be the flow would be very slow. This is normal.
Richard
03-22-2019, 02:46 PM
Livingston
I too have had good luck with TSP. Another thing I have had success with was powered dish washer detergent (Cascade, etc), which is less harsh than TSP.
2019 Flying Cloud 27FB
2011 F350, SB SCREW SD
“Be thankful we’re not getting all the government we’re paying for” Will Rogers
03-22-2019, 03:18 PM
2015 30' Classic
Saint Augustine
Tank Cleaner
This is what I used to clean my tanks:
EXTREME CLEANER by Happy Campers - RV & Marine Extreme Tank & Sensor Cleaner
It worked like a charm. It was, just as aside, recommended by the tank indicator manufacturer: Garnet.
03-27-2019, 11:38 AM
Portland
, Oregon
Originally Posted by RACuthbert
Hello,
Thank you to all of the replies.
I will work my way through the options provided with
absolute confidence my problem will be solved in short
order.
