Old 08-30-2010, 03:27 PM   #1
1964 28' Ambassador
Brooksville , Florida
Changing black water tank.
Looking to change the black water tank in my 64 Ambassodor. It seems to be leaking. My question is do i need to take out the bathroom and pull it from the inside, or can I do everything from the bottom?
stump1250 is offline   Reply With Quote
Old 08-30-2010, 03:46 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Wow! Seems to be the topic of the week for 1964's...
We are getting ready to work on ours in our '64 GT this weekend and then there's these two threads:
http://www.airforums.com/forums/f444...ons-68720.html
http://www.airforums.com/forums/f155...elp-66441.html
Too funny! At least we'll all be able to commiserate and compare notes together...
Shari
P.S. Welcome to the forums!
Old 08-30-2010, 04:34 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Location of the tank dictate replacement procedures,
If your tank is under the floor, the belly pan in the rear will need to be removed to facilitate replacement.
If your tank is above the floor, yes it can be removed from the bathroom.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 08-30-2010, 04:38 PM   #4
That tank is removed from the bottom of the trailer.
Old 09-05-2010, 09:35 PM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Originally Posted by InsideOut View Post
We are getting ready to work on ours in our '64 GT this weekend...
I started a thread for the work on our '64 GT's black tank... http://www.airforums.com/forums/f155...tlc-69086.html. It may help you with yours...
Shari
water inlet to black water tank blocked mbarker Waste Systems, Tanks & Totes 4 11-22-2009 08:54 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
Changing out the Black water tank AccessMaster Airstream Motorhome Forums 8 08-30-2003 08:03 AM
