Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-18-2007, 09:02 AM   #1
1965 17' Caravel
1973 31' Sovereign
1987 32' Excella
Streator , Illinois
Caravel Tank Replacement
I have a 65 Caravel that I have to replace the black water tank . Looks to be cracked along the top . Also at that time I would replace the valve and fitting . Does any one have any experience with this or any pointers . Is it possible to replace with out pulling the whole shower out ?
Also source for new tank and hardware .
Thanks , Jeff
upunover is offline   Reply With Quote
Old 06-21-2007, 11:56 AM   #2
Thanks , Jeff
Jeff.
We have that tank. It's made with fiberglass.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-04-2007, 11:23 AM   #3
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
What ever you decide. Replace the old tank. It will only cause you grief if you try to fix it. By now they are very brittle. Trust me, I dropped mine when I took it out. It nearly shattered. I was replacing it anyway but was surprised to see how brittle it really was.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-04-2007, 01:50 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Reference the forems
Check this out.
http://www.airforums.com/forums/f137...day-22840.html
caravel
White water tank drain ramoore53 Fresh Water Systems 5 02-19-2024 04:08 AM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
Restoration of our Airstreamer Caravel Hagen 1956 - 1965 Caravel 2 11-10-2002 02:15 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
