Old 02-14-2008, 07:08 PM   #15
_
Originally Posted by vhord
... Are torsion axles designed so that if the rubber totally gives way the inter axle will not totally spin?...
spindle/hub and torsion bits are different parts of the full axle assembly...
cheers
2air'
Old 02-14-2008, 07:09 PM   #16
I towed it 40 miles last week and the hubs stayed cool. I feel comfortable with that although I may still check out the bearings & etc. I have helped build many trailers in the last years but have never worked with torsion axles, just leaf spring and straight axles. Are torsion axles designed so that if the rubber totally gives way the inter axle will not totally spin? That would be my main concern. May be a dumb question.
The rubber rods when good, they keep the starting angle good, so that the trailer has adequate ground clearance as well as other things.
When the starting angle goes bad, then the trailer will bottom out.
In may last post, I said that a gutted trailer will bottom out even worse, assuming bad axles (rubber rods).
When the trailer payload has been greatly reduced, then the combination of stiff axles, and not much weight, will make the trailer bounce around on the road.
As an example, if a 26 foot trailer had 2600 axles that were bad, then bouncing and bottoming out will happen.
To haul a gutted 26 foot trailer, perhaps the axles should be 1200 pounds.
Therefore since the axle rating will not change, a gutted trailer will bounce all over the place, and even more so with bad axles.
Old 02-15-2008, 05:51 AM   #17
vhord's Avatar
Images: 96
I get the point.
Vernon
vhord is offline   Reply With Quote
Black Rock Mountain State Park GA. gparker On The Road... 4 05-20-2010 04:50 PM
1954 Cruiser 26' Park Model Question WHR 1950 - 1958 Cruiser 11 12-10-2006 07:03 AM
Do I have to use the Black Tank? jimsease Waste Systems, Tanks & Totes 8 08-09-2006 10:22 PM
Model Confusion and tank capacity Islander Classic Motorhomes 4 06-18-2006 04:10 PM
Black tank Gunnyusmc All Argosy Trailers 4 07-19-2004 04:42 PM
