Old 08-31-2015, 11:04 AM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
cable-actuated dump valve
Anyone ever install one of these?
I'm in the process of plumbing up my new retro-fitted tanks, and finding it quite difficult to get everything connected. (space issues! fittings consume a lot more space than one might expect). Part of the solution might be to use one of these cable-actuated dump valves, but I'd need to know exactly how much space would be needed...namely, exactly how sharply can the cable be bent?
I'll need the cable to be able to make a 90-degree turn inside a 12" space.
The pipe I'm attaching it to runs parallel to the main frame rails, so, the valve body is perpendicular to the frame rails; I'll want it to turn 90 degrees, and exit into the bumper compartment.
I couldn't find any installation instructions for these valves online, but I'm sure there is a limit to how tight a radius you can have with that cable.
If it doesn't work, I can just use a standard valve, add an extension, and go out the side through the frame. Its just not the most convenient spot.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-03-2015, 11:36 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Really? no one has ever used one of these?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-03-2015, 12:18 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I plan on using them. I am also going to cut in an access panel at each valve location, just in case.......
Old 10-18-2015, 05:02 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I bought the cable valve...the body is much larger than the standard valve.
The only way it will work is if I run the cable all the way over to the street side, then turn 90 degrees and head aft into the bumper compartment. (have to get over to the street side because the tank bottom is wedge-shaped, creating space under the tank.). The handle attachment is big, too..a 6" long heavy threaded bolt...needs a 5/8ths hole to mount.
The black tank is only 2" in from the bumper compartment, but there is space way over toward the street side.
For some reason, having the dump valve handle "way over there" seems odd to me. I can't put my finger on "why" this bothers me. I guess I just want to be sure before I drill a big hole.
so anyway, I have a choice: stick with the original standard valve, use an extension rod and a bracket. Or go with the cable valve handle in the trunk.
In the pic, bumper compartment is to the left; street side corner is at the top. conventional grey valve is in place; cable valve would have to be installed 180 degrees to this orientation, with the cable running parallel to the black tank.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 10-18-2015, 06:37 AM   #5
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
These sound great! Can they be set up so you can open them when you are driving down the freeway? Save a bunch of money in dump fees, and time of course.
1989 345LE
Punch is offline   Reply With Quote
Old 10-18-2015, 09:05 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
LOL! well, they do make (much more expensive) ones that are controlled from a switch inside the camper. But that is an entirely different subject.
Air:291
Wbcci: 3752
'73 Safari 23'
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Tedford dump valve 77caravaner Waste Systems, Tanks & Totes 0 09-29-2002 04:58 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 12:19 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
