Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 03-19-2004, 04:47 PM   #1
westeagle
westeagle's Avatar
Profile:
Bypassing Blackwater Tank
Hi
I recently acquired a 1971 31' AS and would like to direct the blackwater and grey water material directly out instead of going into the holding tank first. Is there a way to do this?
I see some valves but don't quite know what position they should be in.
I don't have a service manual yet.
Any instruction would help.
westeagle is offline   Reply With Quote
Old 03-19-2004, 05:20 PM   #2
mandolindave
mandolindave's Avatar
Profile:
The toilet usually empties right into the black water tank.
You could hook up to the sewer and leave the valves open.
But the common method is to let the black tank fill up
and it's mass, weight , and liquid will help the evacuation. Then use the toilet to flush the black tank and the grey water to flush the hoses.
If you rig is new to you, maybe you could experiment with water.
mandolindave is offline   Reply With Quote
Old 03-19-2004, 05:22 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
You can take the drain cap off the sewer outlet, hook up a sewer hose to a sewer, which will take care of the gray water.
under no circumstances, attempt to open the dump valve and leave it continuously open.
If you do, solids will not be washed away, therefore they will accumulate. When that happens, your in deeeeeeeep trouble.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 03-19-2004, 06:35 PM   #4
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Without sufficient water flow the 'solid' waste material will dry & ...(no pictures please)!
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
