Old 08-06-2006, 09:48 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Busted the black plastic handle off one of my dump valve gates
Guess it got brittle after all these years. Pulled on it the other day to dump the tank and it crumbled in my hand. Is there any way to fix this without replacing the whole valve shaft?
wacnstac is offline   Reply With Quote
Old 08-07-2006, 12:20 AM   #2
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Sounds like its time for a new valve. Thats what I would do anyway. They do make extension shafts, maybe you could modify one of those to fit your old shaft.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 08-07-2006, 05:53 AM   #3
Images: 43
Where would one find an extension shaft? I just had new valves put on the thing so they are not coming off again.
Old 08-07-2006, 06:13 AM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Was it just the handle or the shaft which broke? My handles are threaded onto the shaft.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-07-2006, 07:41 AM   #5
Images: 43
It was jus the plastic handle. Didn't appear to be threaded on there but rather molded the end of the shaft. The end of the shaft has a machined out area towards the top end to help keep the plastic in place.
Old 08-07-2006, 08:29 AM   #6
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
I found an extension shaft at my local RV parts house.
Project 2k5
Old 08-07-2006, 08:42 AM   #7
Images: 43
What does an extension shaft look like? How long are they?
Old 08-07-2006, 09:23 AM   #8
2006 30' Classic
Farmington , New Mexico
Images: 14
If a handle can't be found it would be easy to tap threads onto the shaft then tap threads into a piece of soft metal stock for a handle. Use a backup nut to keep the handle in place.----Pieman
Mike Lewis is offline   Reply With Quote
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
