Old 07-15-2004, 09:53 AM   #1
Broken graywater tank
I have a 27ft. 1974 overlander and the graywater tank has a bad crack in it.I was wondering what was the easiest way to get it out.Any help would be appreciated.
Eric74 is offline   Reply With Quote
Old 07-15-2004, 11:14 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
If it is mounted like a fresh water tank, then you will have a frame with the rear facing section being bolted on. Undo the bolts, and pull out the framing piece.
You should be able to then slide out a plywood sheet, which holds up the tank.
This sheet might be very very tight inside it's framework, possible swollen and rotten if teh tank has been leaking.
If you don't see this frame work, then you will have to drop the center section of the belly pan, behind the rear axle to the bumper. Access the tank this way.
Uwe
www.area63productions.com
1964 GT Black Tank Support System? Globestream Waste Systems, Tanks & Totes 2 06-08-2004 10:32 AM
Water Tank Leak - broken part suggestions? gklott Our Community 3 05-02-2004 03:53 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
