Old 03-02-2016, 07:14 PM   #1
1976 25' Tradewind
Sulphur , Louisiana
Bought the wrong kind of 90s
Replacing both of my leaky black water and grey water valves. So I figured just replace all the pvc fittings too. I bought, cut, and glued about $30 worth of 3 inch pvc only to discover the 90s I bought were sweeping 90s and not the short 90s that came out of the airstream. (76 trade wind) So none of the new pipe and valves line up with anything. The valves just bolted on so I just took those off. Everything else is in the trash. The uploaded pic is the old setup. Back to lowes to buy it all again. Click image for larger version
Name:	ImageUploadedByAirstream Forums1456967597.962675.jpg
Bobkatbry is offline   Reply With Quote
Old 03-02-2016, 07:16 PM   #2
1976 25' Tradewind
Sulphur , Louisiana
I hacked it of at the Y so I could pull it out from under the floor.
Old 03-02-2016, 09:31 PM   #3
1998 30' Excella 1000
Livingston , Texas
Plus, there are different degrees of "sweep".
When I do this sort of repair, I bring the original to the store and lay it on the floor to match up the new fittings. Don't ask me why.
Siegmann is offline   Reply With Quote
Old 03-02-2016, 09:34 PM   #4
Ottawa , ON
30 bucks isn't expensive for a plumbing lesson.
Label this one "Dry fit first".
Old 03-03-2016, 12:03 PM   #5
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Plumbing has always given me fits. Heck, I could have a 1’ section of PVC and the dang thing would leak in the middle if I got a hold of it...
Now electrical, that I can understand...
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 03-03-2016, 02:24 PM   #6
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I did the same when I replaced the plumbing in my safari.
Also, the valves have to be on a bit of an angle for the handles to meet the holes in the frame and below the bumper. It looks like sloppy work until you put it all together.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 03-03-2016, 04:49 PM   #7
2005 22' Safari
Half Moon Bay , California
Seems to me that for waste piping, you should be using ABS pipe (Black) not white PVC.
Wider variety of elbows, sweeps, et al.
There is is reason why plumbers make big bucks.
jsutro is offline   Reply With Quote
Old 03-04-2016, 12:30 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
ABS is used because it is cheaper than PVC. Nothing wrong with using either.
Where I live you can not find ABS.
Old 03-04-2016, 11:02 AM   #9
Livingston , Texas
Oh, and be careful of mixing the two. There is a special transition cement, but it's generally hard to find because I don't think it's residential code approved in most locations.
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 06:02 PM
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 08:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 08:04 AM
Bought the wrong hose azfiredog300 Waste Systems, Tanks & Totes 24 06-14-2008 06:13 PM
coach width change from 80s to 90s bake315 1989-1992 Limited 0 04-20-2004 04:34 PM
