Old 04-24-2015, 11:26 AM   #1
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Blue Boy too high for drainage
I bought a 30 gal. Barker waste tote for use with our 2014 FC 25FB, with the intent to use it to drain gray and black water (without solids) into. I discovered that the top of the tote and my AS drain is about the same height so if the tote is under the edge of the AS, it would be difficult if not impossible to fill. I realize I could try to move the tote to a lower location and use a longer hose, but that might not be practical at many RV parks, etc. What are the solutions that others use?
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 04-24-2015, 11:27 AM   #2
dznf0g's Avatar
Oswego , Illinois
You already have your answer, short of getting a macerator pump. I use an extension hose and find a lower spot for the blue boy.
Why no solids in the blue boy??????? I've used mine for everything for 20 years.
-Rich-
Old 04-24-2015, 11:35 AM   #3
Will_Brule's Avatar
Palestine , Texas
Reason for no solids has nothing to do with the blue boy. I normally use a Sewer Solution which I really like, when I have full hook-up or at a dump station. I just find it is faster and simpler when no solids are involved.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
Old 04-24-2015, 11:37 AM   #4
dznf0g's Avatar
Oswego , Illinois
I see. My misunderstanding.
-Rich-
Old 04-24-2015, 11:44 AM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
2x8 under wheels will give you an inch and half so two stacked should give you enough height to drain a short hose. Make up a very short one specific for the blue boy, as long as it is only liquids you could use garden hose fitting end cap and find the largest inside diameter garden hose. Sewer Solutions wouldn't work due to the large volume of water used to push the sewage, however it's large diameter 1" hose could be used.
Old 04-24-2015, 11:47 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Use leveling blocks all around to raise the trailer.
I haven't actually done that; my Interstate discharges through a macerator pump. But it occurred to me when I read your post that if the blue boy can't go down, then the trailer must go up.
On Edit— great minds think alike, DaveFL!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-24-2015, 11:50 AM   #7
dznf0g's Avatar
Oswego , Illinois
That's fine....until you're all set up, and then realize you're too low. I have found the extension hose to be the most flexible......I'm just sayin'....
-Rich-
Old 04-24-2015, 11:51 AM   #8
Will_Brule's Avatar
Palestine , Texas
Yep. Raise the AS or lower the tote. I suppose I was just looking for some "magic" that didn't involve the laws of physics. Doesn't work very often, but then, I have always been a bit crazy. Thanks.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
Old 04-24-2015, 11:55 AM   #9
dznf0g's Avatar
Oswego , Illinois
Oh, there's magic...if you want to spent the bucks on the macerator pump.
-Rich-
Old 04-24-2015, 11:59 AM   #10
I can see where that would be annoying. But if one is planning to use the Blue Boy, then it's easy enough to raise the trailer when you first park it, even if it later proves unnecessary. Better too high than too low.
WBCCI #1105
TAC LA-4
Old 04-25-2015, 05:32 PM   #11
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
If its just for draining and you don't need to leave it under the trailer the whole time, a simple solution would be to drop your nose to raise your butt :-)
thesignlady is offline   Reply With Quote
Old 04-25-2015, 06:19 PM   #12
Will_Brule's Avatar
Palestine , Texas
the sign lady. If you are referring to the AS, that would not make any difference. The black/gray outlet exits the road side, pretty much mid-way between the front and rear of the AS.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
Old 04-25-2015, 07:09 PM   #13
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Also keep in mind the tanks should be higher up inside of the AS than the hook up. That might be enough.
Silverflames is offline   Reply With Quote
Old 04-25-2015, 07:25 PM   #14
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I realize you already bought your tote, but another solution would be to go to a smaller tote that sits lower. Barker makes a 15 gallon flat tank that is only 7" tall at the fill cap. Barker 15 Gallon Folding Tent Camper Tote- Along Portable Holding Tank - Portable Holding Tanks - Black Water Tanks - Plumbing
I use a standard Barker 15 gallon tote and even it it sits lower than the 30. I don't have a problem with it.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
hydraulic leveler question - how high is too high? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 04-06-2013 11:33 AM
Boy Oh Boy! my new '56 Flying Cloud! urbanfood 1956 - 1959 Flying Cloud 169 07-18-2012 07:24 AM
Gas Prices for 2011 - How high is too high to tow? Kosm1o On The Road... 77 01-02-2011 09:48 PM
Oh boy, Oh boy till Our Community 19 05-05-2005 07:26 PM
