04-24-2015, 11:26 AM
2014 25' FB Flying Cloud
Palestine
Blue Boy too high for drainage
I bought a 30 gal. Barker waste tote for use with our 2014 FC 25FB, with the intent to use it to drain gray and black water (without solids) into. I discovered that the top of the tote and my AS drain is about the same height so if the tote is under the edge of the AS, it would be difficult if not impossible to fill. I realize I could try to move the tote to a lower location and use a longer hose, but that might not be practical at many RV parks, etc. What are the solutions that others use?
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
04-24-2015, 11:27 AM
Oswego
You already have your answer, short of getting a macerator pump. I use an extension hose and find a lower spot for the blue boy.
Why no solids in the blue boy??????? I've used mine for everything for 20 years.
-Rich-
04-24-2015, 11:35 AM
Palestine
Reason for no solids has nothing to do with the blue boy. I normally use a Sewer Solution which I really like, when I have full hook-up or at a dump station. I just find it is faster and simpler when no solids are involved.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
04-24-2015, 11:37 AM
Oswego
I see. My misunderstanding.
-Rich-
04-24-2015, 11:44 AM
2000 31' Land Yacht
Central
2x8 under wheels will give you an inch and half so two stacked should give you enough height to drain a short hose. Make up a very short one specific for the blue boy, as long as it is only liquids you could use garden hose fitting end cap and find the largest inside diameter garden hose. Sewer Solutions wouldn't work due to the large volume of water used to push the sewage, however it's large diameter 1" hose could be used.
04-24-2015, 11:47 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Use leveling blocks all around to raise the trailer.
I haven't actually done that; my Interstate discharges through a macerator pump. But it occurred to me when I read your post that if the blue boy can't go down, then the trailer must go up.
On Edit— great minds think alike, DaveFL!
04-24-2015, 11:50 AM
Oswego
That's fine....until you're all set up, and then realize you're too low. I have found the extension hose to be the most flexible......I'm just sayin'....
-Rich-
04-24-2015, 11:51 AM
Palestine
Yep. Raise the AS or lower the tote. I suppose I was just looking for some "magic" that didn't involve the laws of physics. Doesn't work very often, but then, I have always been a bit crazy. Thanks.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
04-24-2015, 11:55 AM
Oswego
Oh, there's magic...if you want to spent the bucks on the macerator pump.
-Rich-
04-24-2015, 11:59 AM
From All Over
I can see where that would be annoying. But if one is planning to use the Blue Boy, then it's easy enough to raise the trailer when you first park it, even if it later proves unnecessary. Better too high than too low.
04-25-2015, 05:32 PM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
If its just for draining and you don't need to leave it under the trailer the whole time, a simple solution would be to drop your nose to raise your butt :-)
04-25-2015, 06:19 PM
Palestine
the sign lady. If you are referring to the AS, that would not make any difference. The black/gray outlet exits the road side, pretty much mid-way between the front and rear of the AS.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
04-25-2015, 07:09 PM
1969 29' Ambassador
brooksville
Also keep in mind the tanks should be higher up inside of the AS than the hook up. That might be enough.
04-25-2015, 10:10 PM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Oohh...on all my trailers it comes out the back end...appropriately enough ;-)
04-30-2015, 11:34 AM
2008 25' Classic
Full Time
Originally Posted by TinShack
How do you get that to the dump station? It must weigh about 120lbs when almost full.
Kelvin
04-30-2015, 12:28 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Kelvin
"A pint's a pound the world around." 8 pints per gallon.... 8 x 30lb is 240 lbs!
Gotta drag it with the tow vehicle right? Or pray the dump station is downhill. I gotta bad feeling that getting it downhill wouldn't be a problem but stopping it might be! Blue boy surfing? Yee-Haw! OH-NO Mr. Bill! Whew boy!
04-30-2015, 01:57 PM
Central
, Mississippi
Get a cap for your sewer dump connection that has a garden hose bib. Leave off the hose bib cap and slide the bluboy under it with the blueboy cap removed. You can then burp the dump valve and let water squirt out the hose bib into the uncapped blue boy. If your outlet points down, this works great. Horizontal exits might require a short piece of garden hose to curve into the blueboy.
No hose required...but ya gotta stop filling the blueboy before it overflows!!!
04-30-2015, 02:10 PM
2005 28' Safari S/O
Paradise
Kelvin
My 15 came with a metal tow hook. One end attaches to the blue boy and the other end loops over your TV tow ball so you can tow it. Heavy? Yes, but with the wheels and handle I can move it myself for short distances, and two people can lift it into the back of the truck if needed. Still much lighter than the 30!
Steve
"THE OLDER I GET, THE BETTER I WAS"
05-29-2015, 04:14 PM
PopHetzler
2003 34' Classic S/O
Troy
, Ohio
I usually dig a hole for the blue boy if on flat ground. If I'm lucky and have a drop off, I use a long hose.
