Old 04-25-2015, 10:10 PM   #15
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Originally Posted by Will_Brule View Post
the sign lady. If you are referring to the AS, that would not make any difference. The black/gray outlet exits the road side, pretty much mid-way between the front and rear of the AS.
Oohh...on all my trailers it comes out the back end...appropriately enough ;-)
thesignlady is offline   Reply With Quote
Old 04-30-2015, 11:34 AM   #16
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Originally Posted by TinShack View Post
I realize you already bought your tote, but another solution would be to go to a smaller tote that sits lower. Barker makes a 15 gallon flat tank that is only 7" tall at the fill cap. Barker 15 Gallon Folding Tent Camper Tote- Along Portable Holding Tank - Portable Holding Tanks - Black Water Tanks - Plumbing
I use a standard Barker 15 gallon tote and even it it sits lower than the 30. I don't have a problem with it.
How do you get that to the dump station? It must weigh about 120lbs when almost full.
Kelvin
Old 04-30-2015, 12:28 PM   #17
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Kelvin
"A pint's a pound the world around." 8 pints per gallon.... 8 x 30lb is 240 lbs!
Gotta drag it with the tow vehicle right? Or pray the dump station is downhill. I gotta bad feeling that getting it downhill wouldn't be a problem but stopping it might be! Blue boy surfing? Yee-Haw! OH-NO Mr. Bill! Whew boy!
Old 04-30-2015, 01:57 PM   #18
Central , Mississippi
Get a cap for your sewer dump connection that has a garden hose bib. Leave off the hose bib cap and slide the bluboy under it with the blueboy cap removed. You can then burp the dump valve and let water squirt out the hose bib into the uncapped blue boy. If your outlet points down, this works great. Horizontal exits might require a short piece of garden hose to curve into the blueboy.
No hose required...but ya gotta stop filling the blueboy before it overflows!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-30-2015, 02:10 PM   #19
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Kelvin
My 15 came with a metal tow hook. One end attaches to the blue boy and the other end loops over your TV tow ball so you can tow it. Heavy? Yes, but with the wheels and handle I can move it myself for short distances, and two people can lift it into the back of the truck if needed. Still much lighter than the 30!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 05-29-2015, 04:14 PM   #20
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
I usually dig a hole for the blue boy if on flat ground. If I'm lucky and have a drop off, I use a long hose.
Emh142 is offline   Reply With Quote
hydraulic leveler question - how high is too high? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 04-06-2013 11:33 AM
Boy Oh Boy! my new '56 Flying Cloud! urbanfood 1956 - 1959 Flying Cloud 169 07-18-2012 07:24 AM
Gas Prices for 2011 - How high is too high to tow? Kosm1o On The Road... 77 01-02-2011 09:48 PM
Oh boy, Oh boy till Our Community 19 05-05-2005 07:26 PM
