Old 08-29-2016, 06:51 PM   #1
Rich and Kat
AIRHEDS's Avatar
Virginia ... near ... , Washington, D.C.
Blackwater Tank: is it possible to use both ...
Thetford 03106 Aqua-Kem and Walex TOI-91799 Deodorizer? I have read great things/reviews about both so using both must, together, must obviously be better ... ?
Just want to make sure it's not kinda like trying to clean with bleach and ammonia ... at the same time (sodium hypochlorite) ...
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 08-29-2016, 06:59 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Why?
2012 Dodge Durango Hemi/AWD
Old 08-29-2016, 07:02 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I stopped using chemicals years ago.
google "geo method"
Alan
Old 08-30-2016, 08:16 PM   #4
Rich and Kat
AIRHEDS's Avatar
Originally Posted by Wayne&Sam View Post
Why?
Because Walex makes the black tank smell good and Aqua-Kem breaks solids down real well... Best of both ...
A W Warn, I'll definitely check out the geo method.
But sill wondering ...
Rich
KB2ZMF
Save
Old 08-31-2016, 01:16 PM   #5
2007 28' Classic
Ivanhoe , Virginia
Black tank stuff
Happy Camper enzyme treatment order from Arizona. Been using 10 years. Does it all.
horseylady is offline   Reply With Quote
Old 08-31-2016, 01:49 PM   #6
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
We do this, works great:
Q) What is the Recipe you recommend for maintaining RV holding tanks?
Recipe will help to sanitize your tanks while creating a slippery coating to help your sensors remain free of blockage.
1 – gallon jug (empty)
1 – 48 oz bottle of Pine-Sol
1/2 cup Calgon (or other brands like Vaseline) Bath Beads (available at Wal-Mart)
Pour 48 oz. of Pine-sol into the empty gallon jug. Add water almost to the top of the jug, leaving enough room for the bath beads. Shake the Pine-sol and water to mix up (let settle), then add 1/2 cup of the Calgon Bath Beads to the mixture. Shake. Depending on the size of your tanks, use 8 oz. for the black tank and 4 oz. for the gray tank. Add more if desired or if you have larger than average tanks. Adding the bath beads causes overflow therefore I recommend mixing outside or in the sink.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 09-01-2016, 05:59 AM   #7
2016 30' Flying Cloud
Blenheim Ontario , Ontario
On a weirder branch of this subject; I have a 2016 30' FC and have just found out out that the bathroom sink drains into the BLACK tank. I wondered why my black tank was filling up so fast.
Airstream says that this is by design on the 30 footers due to configuration and weight and balance.
I have never had a previous trailer do this including the 25 ft Cloud.
So now I must empty black tank every two or three days, instead of weekly.
Goofy, eh wot!
MelGoddard is offline   Reply With Quote
Old 09-01-2016, 06:02 AM   #8
Gainesville , Florida
It's án advantage. More liquid in Black tank. Don't overuse the bath sink.
Old 09-01-2016, 06:51 AM   #9
mandolindave's Avatar
Lose the chemicals
Use an Enzyme treatment
mandolindave is offline   Reply With Quote
Old 09-01-2016, 08:03 AM   #10
Wayne&Sam's Avatar
Images: 21
Goofy, eh wot!
My 25'FC does this too. It's a plus to me. More liquid in the tank and helps keep the grey tank from filling.
Old 09-01-2016, 08:14 AM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our Safari 20 and our FC 25 both drained the bath sink into the black tank. This is a good design as our gray tank fills first.
Doug and Cheryl
Old 09-01-2016, 07:59 PM   #12
So what do you 'boondockers' do?
Go find a dump station every two days?
The black tank should last 5-7 days.
Grey water can be used to water the flowers.
Black tank to gray tank conversion. Is it possible? Blu_Hwy_Lady Plumbing - Systems & Fixtures 11 03-11-2016 11:05 AM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
Blackwater tank flush inlet jordandvm Waste Systems, Tanks & Totes 2 10-26-2004 05:02 AM
Bypassing Blackwater Tank westeagle Waste Systems, Tanks & Totes 3 03-19-2004 06:35 PM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
