Old 02-05-2008, 08:26 PM   #15
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Now to get it back in
Found an appropriate flange, apparantly they are all plastic now. To compensate for it not having a metal part, I purchased a "tabbed" flange(metal) at Home Depot, and re-fit it to go under the plastic flange. I drilled the metal to match the holes in the plastic one so I can use stainless steel screws to pass through the plastic, then through the steel, then into the 3/4 inch plywood floor. That way I have the plastic flange attached to the metal flange attached to the floor. Being "horizontally challanged" (read fat) I want all of the support I can get to hold the toilet level and steady. Had a friend who once ended up in a jam when the floor gave way beneath the toilet in his mobile home. Not a pretty mental picture. How do you explain that to the rescue squad, whose members will not stop laughing long enough to perform a proper extraction?
Pressing on,
bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 02-06-2008, 02:19 PM   #16
pauly g's Avatar
1960 22' Safari
Oceanside , California
When I was a kid, I remember my grandmother being thrown off the toilet as it broke free of the floor in my grandparents trailer. She was young at the time, so no extraction was needed. I guess it is important to mount the toilet securely.
pauly g is offline   Reply With Quote
Old 05-31-2008, 12:49 PM   #17
1973 31' Sovereign
1960 24' Tradewind
1953 21' Flying Cloud
Fort Worth , Texas
But how do you get the black water tank out, because it is leaking?
bjwagenor is offline   Reply With Quote
Old 06-01-2008, 01:05 PM   #18
The black water tank for your Airstream, is below the floor.
You should find a large rectangular box that covers it up, underneath the fllor.
Old 06-02-2008, 12:27 PM   #19
1973 31' Sovereign
1960 24' Tradewind
Fort Worth , Texas
No, my tank is the orginal & it is above the ground. But we finally got it out!
Old 10-31-2014, 09:20 AM   #20
1967 26' Overlander
Amity , Arkansas
flange
I couldn't get the flange out of my 1967 waste tank. The floor was bad and I cut it out and even tried a 36 inch pipe wrench. Finally used an air chisel and hammered it out after breaking the metal flange to pieces. I think it was glued in. Have to try to repair the threads now
Johngould is offline   Reply With Quote
Old 10-31-2014, 09:40 AM   #21
No, the flange was not glue in by Airstream, but they were difficult to remoce 40 years ago.
Best way, is as you did, break the metal flange in pieces.
broken flange on blackwater tank? 1971 vintagemike Waste Systems, Tanks & Totes 13 12-14-2007 07:04 PM
Blackwater tank repair tbrom Waste Systems, Tanks & Totes 17 07-18-2007 06:11 AM
Need flange for my toilet-b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 7 01-24-2006 08:07 PM
Bypassing Blackwater Tank westeagle Waste Systems, Tanks & Totes 3 03-19-2004 06:35 PM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
