Old 09-09-2009, 06:20 PM   #1
1961 24' Tradewind
wayland , Michigan
Blackwater tank drain
Ok we have a 1961 tradewind with the rear bath,we want to remove the black water tank to repair it the question is how do we remove the 90 degree elbow from the bottom of the tank without breaking it? is it threaded or glued or what it appears to be either aluminum or cast. not sure witch just trying to avoid ruining that tank to keep costs down on the remodel job, any help with this would be great, thanks in advance.
Tad Pole is offline   Reply With Quote
Old 09-11-2009, 08:26 AM   #2
1961 24' Tradewind
wayland , Michigan
anyone? anyone?
Old 09-11-2009, 09:08 AM   #3
Ottawa , ON
Tadpole,
Can you post a picture of the tank and the elbow you want to remove? It might help to get an answer, but no guarantees...
Old 09-11-2009, 09:09 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Hmmmm, not sure if your's is the same set-up as our '66. I replaced ours 3 years ago and had to cut a PVC elbow sewer pipe that was glued. It was no issue to glue a new elbow in.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
FreshAir is offline   Reply With Quote
Old 10-15-2009, 02:55 PM   #5
1961 24' Tradewind
wayland , Michigan
Ok i finially have a pic of this thing,any help would be great.thanks in advance
Hope this helps Thanks again
Old 10-15-2009, 03:02 PM   #6
Images: 59
I'm afraid you have a bigger problem than the elbow. If you can get the elbow off you still need to disconnect the graywater connectors and remove the big ol' valve on the bottom of the tank before you can lift out the tank. And that'll be way harder than the elbow.
Better start unscrewing that aluminum panel so you can look up in there.
Old 10-15-2009, 04:33 PM   #7
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
The elbow is the same as was on my '61 Safari. It is aluminum. To remove it you must turn it counterclockwise about a quarter of a turn and then it will drop straight down. The problem you may encounter is that it might be severely corroded and the force needed to turn it may damage something else. There is a big brass valve above it that is screwed to the bottom of the black tank with 4 screws and has a couple of grey water lines attached. My suggestion is to put some Liquid Wrench or other corrosion loosener around the top so it will drain down into the inside of the elbow. Tap it with a hammer and use some heat (but not enough to melt aluminum or start a fire) then unscrew it with a pipe wrench. It has/had a rubber gasket to help prevent leaks.
And what markdoane says..........
Sam
samb is offline   Reply With Quote
Thetford Drain Valve - Blackwater JHBurns100 Waste Systems, Tanks & Totes 15 04-07-2009 09:39 AM
64 GT Blackwater tank 64TrotterAtl Waste Systems, Tanks & Totes 4 09-27-2008 11:48 PM
New Blackwater tank Tom Bray Waste Systems, Tanks & Totes 5 07-10-2008 07:24 AM
Blackwater drain valve problem aluminator34 Waste Systems, Tanks & Totes 4 07-09-2007 11:22 AM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
