Old 08-09-2016, 04:30 PM   #1
MontyV's Avatar
1994 34' Limited
Salem , Oregon
black water valve
we have a 94' classic limited. The drain tube fills with black water. The tank valves are just T handles that you pull to open and push to close. The black water side just doesn't seem to close all the way. Is there a way to get in there and see if something is stuck blocking the gate without cutting holes? or are there other ideas or suggestions from the collective experience?
MontyV is offline   Reply With Quote
Old 08-09-2016, 05:05 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can get a twist on Valterra valve that will fit where the sewer hose connects. Put it on, put the end cap on and you are set. At least you won't have the mess of black water when you remove the end cap.
You can get the Valterra valve online or maybe at CW.
Old 08-09-2016, 05:12 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I believe the plumbing on the 94 is Thetford. If it is you can get a Thetford to Valterra adapter and proceed as above, Thetfoird now makes limited plumbing parts.
Your 22 year old Thetford valve has had a good life. Replace it with Valterra which does not need to be glued in. While you are at it you might as well do the grey water valve.
Old 08-09-2016, 05:21 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
This thread is a good place to get some information about the pipe layout.
http://www.airforums.com/forums/f444...ed-139672.html
You could use a small mirror on a stick with a flashlight, or an inspection camera, to look inside the valve.
Alan
Old 08-10-2016, 06:09 AM   #5
1991 25' Excella
Hartford , Wisconsin
Recent
Here is a link to my recent dealings with this problem with part numbers and costs
http://www.airforums.com/forums/f444...-a-153935.html
TOPORANGER is offline   Reply With Quote
1965 Safari gas manifold, valve and new water valve avdindenver Airstream Classifieds 0 12-09-2015 09:53 AM
Sticky Black Water Valve squeeky Waste Systems, Tanks & Totes 3 04-09-2004 10:47 AM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
Black Water Valve Opinion Deppdog Waste Systems, Tanks & Totes 4 09-11-2003 04:27 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
