Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 07-03-2008, 05:25 PM   #1
tntom
Profile:  1999 28' Excella
Fayetteville , Tennessee
Black Water Tank Shut-off Leaking
Just acquired a 1999 Excella with a leaking shut-off on the black water tank. Not a good experience trying to beat the flow hooking the drain hose. Bought an external shut-off but extends out beyond the side of AS and does not fit tight enough to withstand the vibration.
Has anyone had experience in replacing the shut-off or would the whole tank need replacing? What would be involved?
tntom is offline   Reply With Quote
Old 07-03-2008, 06:28 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Replacing the valves is usually a piece of cake.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 07-03-2008, 06:38 PM   #3
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
I have done this on an older AS - a 66 Caravel. Really - I only took it apart and cleaned it. You may find the gaskets have rotted or may be as simple as TP clogging the grove where the slide valve goes into. A cleaning may get you back on the road but for your late model valve body there are repair kits available from most RV stores and from an AS dealer. That would be a start and as Andy says above - it's not to hard but I would not have "cake" in my answer to you - seems a little out of place in a discussion over a dump valve.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
black water
Leaking fresh water tank turbo8 Fresh Water Systems 5 08-19-2007 12:44 AM
Black water shut off valve? '73 Sovereign Al Falcon Waste Systems, Tanks & Totes 10 05-14-2007 04:28 AM
Leaking Fresh Water Tank gaylejoe Fresh Water Systems 9 09-30-2006 07:04 PM
Leaking Hot Water Tank or tap? hubrik Water Heaters, Filters & Pumps 5 01-27-2006 01:04 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
