02-28-2011, 07:58 AM
1975 23' Safari
Baton rouge
, Louisiana
Black water tank removal 1975
I'm trying to remove my black water tank below the toilet and can't figure out how to reach the bolts below the floor. Does anyone know any tricks?
02-28-2011, 08:46 AM
Jupiter
Have you pulled the plywood flooring and are trying to lift the tank out from above? It's been a while, but there are no hidden fasteners for the tank itself.
On my '73 the BW tank nested 'loose' inside a galvanized cover and was supported underneath and sides by a foam spacers - no bolts unless you're trying to remove the sheet metal tank house, then its remove belly wrap to drop the angle iron supports. Maybe someone else has a better take on it...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
02-28-2011, 09:19 AM
1974 Argosy 26
Morrill
, Nebraska
No fasteners
If it is like my '74 Argosy you must disconnect it from the waste dump piping below the tank. My access is thru the storage compartment in front of the rear bumper. There is a big hose clamp that fastens it to the piping. Then the tank slides toward the curb side as you lift it out. There are no fasteners in mine that hold the tank to the floor.
02-28-2011, 09:31 AM
2007 25' International CCD FB
1961 16' Bambi
1956 16' Bubble
Potrero
Mus289,
I had no bolts from underneath the tank. It just sat on a platform with foam padding. Up near the top flange, two bolts held the toilet, and the top flange was screwed onto the tank flange. I made a tool to go into the two slots in the top flange out of aluminum. Not sure if yours is the same.
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1961 Bambi, 16' California
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
( View all of elfirebob's images)
02-28-2011, 11:39 AM
1968 24' Tradewind
Oxford,
, Mississippi
Make sure you have the vent stack disconnected. On my 68, the tank is supported in the galvanized box. The only thing that holds it "up" is the toilet flange which you unscrew from the fitting in the top of the tank. If it won't turn, you may have use a stick and catch the edge of the hole where the toilet bolts are and then gently tap is to the left (lefty loosey" to unscrew it from the tank. You may have to cut the vent pipe, if you do make sure you cut in in a location where you can have good access so you can use a coupler to put it back together.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
11-28-2011, 05:25 AM
1997 31' Land Yacht
fort walton bch
blackwater tank
need advise on removing my tank from my 97 30ft airstream mh have the comode an vent pipe also the drain valves under control. wondering if i can drill two rivets out just inside the drain exces door an remove panel between door an rear wheel to have easy excess to the bolts that hlod the cover up over the tank.
any help really appreciated
charlie down in fl panhandle
11-29-2011, 07:38 AM
Streamin'
1995 30' Cutter Bus LE
Madison
, New Mexico
Hi Charley, I just ran across your post. My only experience with the black tank is replacing the drain valve. I would like to replace the level sensors so I was checking on your project.
And an Air Forum posting suggestion… You may want to also post this on the Land Yacht/Legacy Motorhomes - Airstream Forums and the Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes - Airstream Forums and start a New Thread and call it Black Tank Removal 30’ Motorhome or something more descriptive.
Bill near Crawfordville FL
04-17-2017, 08:27 AM
1974 Argosy 26
Longmont
I'm actually just reading this because I'm trying to remove my black tank on a '74 Argosy.Thanks for posting. It's just what I'm looking for.
