Old 04-13-2010, 11:47 AM   #1
1971 23' Safari
Clyd , Texas
Black Water Tank questions
Hello to you all.I am looking for a Black Water Tank for my 1971 Airstream Safari Land Yacht.I've looked everywhere I can think of.Can anyone give me some advise on where to look are if they have information about this please contact me.If you need more information let me know.I need one asap.Thanks.New Member.Mike Hall
Mike Hall is offline   Reply With Quote
Old 05-04-2010, 06:45 PM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Welcome to the forum - you might try
www.inlandrv.com
or
www.vintagetrailersupply.com
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 05-04-2010, 06:56 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Welcome to the forums. I got a new black tank for my 68 Trade Wind from Inland. It is an exact reproduction of the factory tank. Wasn't cheap, but well worth the money for the time saved trying to make something else work.
Old 05-04-2010, 07:07 PM   #4
Ottawa , ON
Assuming your original had them, did the replacement tank you bought have the sensors? (empty. 1/2 full, etc)?
Old 05-04-2010, 09:20 PM   #5
68 TWind's Avatar
1968 24' Tradewind
No, just the plain tank. It came with the fittings for the toilet flange and the vent stack but they are not installed. The new tank is a nice heavy gel coat fiberglass. That was a good thing, because it allows you to position the tank in the tank box exactly where you want it, put it in place under the trailer and then mark the location for the flange on top of the tank through the center of the toilet flange. Take the new tank down and cut the hole in the top of the new tank and fiberglass the fitting into place. Was really easy. Same for the vent.
Black water tank questions Globie64 Waste Systems, Tanks & Totes 8 04-12-2010 07:45 PM
water inlet to black water tank blocked mbarker Waste Systems, Tanks & Totes 4 11-22-2009 08:54 PM
More black tank questions SilverHoot Waste Systems, Tanks & Totes 22 06-28-2009 06:53 PM
black tank/water heater repair questions kdenault Waste Systems, Tanks & Totes 2 07-14-2006 06:44 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
