Old 04-04-2010, 03:07 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Black water tank questions
Hi, we've never used our '64 Globetrotter other than in our own driveway, and have never used the black water tank. We need the hose that connects to the tank to drain, any thoughts about where to get one would be a huge help.
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-04-2010, 03:47 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Do you have the lock on connector? The original was a Thetford,something do don`t just buy at your local RV shop.I found mine on Ebay.Maybe someone will post where you can buy,if not cut off the original and add 1 of the modern connectors.Not sure of the name of the new style. Dave
easyride is offline   Reply With Quote
Old 04-04-2010, 03:56 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
New Airstreams use the more common Valterra fittings. You can find the ones you need at VTS.
Thetford Valves & Fittings
Richard
Old 04-04-2010, 04:13 PM   #4
Globie64's Avatar
Images: 18
Hi, thats a great help. Learning about another mysterious Airstream system...
Old 04-04-2010, 05:37 PM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Camping World has what you need. You most likely have a Thetford connector from your tank, But Valterra has an adapter to the hose. Check with me and several others when you are at Casini Rally this week. I have the hookup that you are looking for. In fact if you need to use my hose ...ask. I now use the Sewer Solution setup but carry the 'slinky' with me....just in case.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-04-2010, 11:06 PM   #6
Globie64's Avatar
Images: 18
Thanks Neil. I was thinking that we wouldn't use the plumbing at all at Casini- it's not quite sorted out. I look forward to seeing other's trailers and how it all works
Peter
Old 04-12-2010, 06:42 PM   #7
Globie64's Avatar
Images: 18
I actually bought a hose and connections from an RV place in Petaluma, and the pieces looked exactly like the old Thetford pieces I have that fit my tank... except for a couple of little bits, which made it impossible to mate to the dump valve. Sigh. We'll get it sorted out, sounds like a trip to Camping World, online. There was someone at Casini with a '64 like ours, that his parents had had. He had some of the original connections for connecting to the black tank, cast aluminum fittings (!) which were amazing, but apparently mine has been retrofitted and his stuff didn't fit. We'll get this sorted out too. Thanks
Old 04-12-2010, 07:02 PM   #8
lucca53
lucca53's Avatar
1973 31' Excella 500
2004 22' Safari
2006 25' Safari
napa , California
Smile
Thanks Azflycaster I want to replace my black valve on my trailer now I know where to get the parts
lucca53 is offline   Reply With Quote
Old 04-12-2010, 07:45 PM   #9
Globie64's Avatar
Images: 18
ok, now I read Easyride's post again, and I get it, you don't just buy stuff that mates to the old stuff anywhere. It's amazing, the tiny difference that made it not work. Going to tackle the tank/toilet and valve stuff- a leak has caused the floor under the toilet to fail and here we go again
water inlet to black water tank blocked mbarker Waste Systems, Tanks & Totes 4 11-22-2009 08:54 PM
More black tank questions SilverHoot Waste Systems, Tanks & Totes 22 06-28-2009 06:53 PM
Toilet/ black water complete replacement questions hickam Waste Systems, Tanks & Totes 5 09-08-2008 07:34 PM
black tank/water heater repair questions kdenault Waste Systems, Tanks & Totes 2 07-14-2006 06:44 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
