Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 07-15-2008, 07:35 AM   #1
Profile:  La Canada , California
Question Black Water Tank-Manual Open?
I recently was dumping my black water tank (1984 Classic Motorhome)when the handle can off in my hand. It was apparently rusted through. Is there a way to open the valve manually? I know the valve needs to be replaced, but I'd like to dump the tank first.
Grovelander
grovelander is offline   Reply With Quote
Old 12-11-2008, 06:11 AM   #2
Profile:  1975 25' Caravanner
santa monica , California
airstream blackwater valve
Have you ever found a solution to your problem, I have the same problem myself.
bulahi is offline   Reply With Quote
Old 12-11-2008, 06:21 AM   #3
Profile:  , Minnesota
Images: 59
Airstream Registry
The last guy with this problem had the best answer. Take it to the dealer.
Some projects don't need to be DIY.
Black Water Tank robertpeters Waste Systems, Tanks & Totes 13 06-13-2007 06:26 PM
need new black water tank KHarris Waste Systems, Tanks & Totes 4 09-24-2006 08:34 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
