Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-16-2009, 12:56 AM   #1
Profile:  1975 25' Tradewind
Sammamish , Washington
Black Water Tank Leak
Looking for a temporary solution to 1) stop toilet from draining due to bad seal and 2) stop black water tank from leaking due to bad seal. Ironically, both seals were fairly good until I used a toilet tank tissue digester and now both have gone bad.
Ultimately I know I will need to replace both but hope to make it through this summer before taking on this project in the fall.
Any simple and tried suggestions that will help me limp through the rest of this camping season. For example, is there a thick lubricant that I can apply to help the toilet seal (i.e. petroleum jelly??). Thanks for any and all input.
nalesueur is offline   Reply With Quote
Old 06-16-2009, 01:18 AM   #2
Commercial Vendor
Profile:  Corona , California
Unfortunately, the only way to stop the holding tank from leaking, is to not use it.
Is it the tank, or the dump valve, that's leaking?
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-19-2009, 12:28 AM   #3
It is the dump valve that is leaking, not the tank. I've been reading the other posts on how to replace it. Sounds straightforward, but not necessarily a quick fix.
Old 06-19-2009, 12:47 AM   #4
Commercial Vendor
With a couple of instructions, you can change that valve in about an hour.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-19-2009, 03:27 PM   #5
Any good recommendations for sources to find repair manuals? We have a 1975 25' tradewind
Old 06-19-2009, 03:37 PM   #6
Profile:  2008 16' Safari
Destrehan , Louisiana
The dump valves are not AS specific. Your local RV dealer should be able to supply the parts. These aren't hard to change, just kind of nasty.
dlb435 is offline   Reply With Quote
Old 06-21-2009, 03:15 PM   #7
JW84345's Avatar
Profile:  1969 27' Overlander
, Michigan
I replaced the dump vaulve on my 69 overalander. What I thought would be a simple repair turned into a 2 weekend job chipping away soaking wet foam, pulling and rebuilding the rusted metal box the black tank is enclosed in, and minor reblumbing to hook it all up.
Works great now.
JW84345 is offline   Reply With Quote
Old 07-18-2009, 06:47 PM   #8
454 310! Yea!!!
MaryContrary's Avatar
Profile:  on the road , California
Images: 27
ohh gawd....i'm scared....
my black water valve leaks, i'm rendering it useless till after a few pints of bleachy water
are there any tips or pointers?
  • 1984 310 Limited Motorhome
The moon of a bright silver, which dazzles by its shining, illumines a world which surely is no longer ours; for it resembles in nothing what may be seen in other lands.
-pierre loti
MaryContrary is offline   Reply With Quote
Old 07-18-2009, 07:05 PM   #9
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
You can put the cap on the end of the tank line. Even if the valve leaks the cap on the end of the line will stop the stuff from coming out.... Until you go to dump it, then be ready for a little mess, have a bucket ready...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-19-2009, 12:28 PM   #10
454 310! Yea!!!
Images: 27
thankfully there is nothing in tank....whew!
but of course it wont hold the bleachy water either...
i'm gonna replace both valves and the Y
i have a 310 motorhome. can anyone tell me if this is a simple afternoon job, or is this a plumbing messy part scavenging nightmare that i should just pay to have fixed?
-pierre loti
Old 07-22-2009, 10:37 PM   #11
JW84345's Avatar
, Michigan
Changing the valve on the motor home is straight forward as the plumbing is readily accessible.
The parts are standard and available.
Best of luck.
Last edited by JW84345; 07-22-2009 at 10:39 PM. Reason: fixed mispelling and added content
Old 08-05-2009, 02:43 PM   #12
mcair's Avatar
Profile:  1988 29' Excella
Collinsville , Illinois
where do you get instructions for this? How do we find out what valve to replace it with? Do you have to take it apart first? A dealer I called asked what color it was. It is enclosed in a metal box where you can't even see it.
mcair is offline   Reply With Quote
Old 08-05-2009, 06:05 PM   #13
Profile:  1992 29' Excella
DFW , Texas
Here is one reference. I went through this process earlier this year.
TxToaster is offline   Reply With Quote
Old 08-24-2009, 09:16 PM   #14
JW84345's Avatar
, Michigan
Called Airstream Parts in Jackson Center. They identified the correct replacement based on model and year. You may need a dealer to drop ship it to you.
Small leak in black water tank InspectorDread Waste Systems, Tanks & Totes 4 12-31-2007 01:13 AM
Black water tank leak $$$$ wacnstac Waste Systems, Tanks & Totes 6 05-08-2006 11:50 AM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-30-2005 12:03 AM
