Old 05-11-2011, 03:10 PM   #15
1989 29' Excella
1973 Argosy 20
1978 24' Argosy 24
cincinnati , Ohio
I need new seals for my dump valve in my 1973 argosy. Nothing at the RV store fit. Any Ideas ? I called Thetford themselves but got no luck.
Cintikaren is offline   Reply With Quote
Old 05-11-2011, 03:31 PM   #16
Plastic shrinks in time. "IF" you found the seals, and installed them, you will spend a bunch of time, that might last a few months.
The best solution is to replace valves that are 38 years old.
New valves will probably last another 38 years.
And, the new valves will save you some headaches and gray hair.
Small leak in black water tank InspectorDread Waste Systems, Tanks & Totes 4 12-31-2007 12:13 AM
Black water tank leak $$$$ wacnstac Waste Systems, Tanks & Totes 6 05-08-2006 10:50 AM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
