Originally Posted by HowieE
One thing I have done for years and it would help in this situation. When dumping I open the black valve and let it flow till near empty. While the black valve is still open lift the hose to above the banana strip and open the gray valve and count to 10. Close the gray valve and drop the hose and let it completely drain. This sends a slug of water back into the black tank and provides a formative flush. Close the black valve and open the gray.
To make this process a bit easier, I use one of these on the tank valve:
https://www.amazon.com/Valterra-T58-.../dp/B000BGHYJS
It's helpful because if either of your tank valves is leaking, it's a second valve to prevent a full-on leak. It eliminates any dribbling when you open your cap.
Also, it helps with the back flush - same procedure above without lifting the hose. Just close this valve while leaving the black valve open. Then open the gray for a bit, close it, and then open the main valve. I repeat this a few times and get a great flush of the black tank.
