02-15-2009, 12:10 PM
2005 28' International CCD
Pittsburgh
, Pennsylvania
Black Water Tank Flush Problem
I've been flushing my black water tank successfully for years. I drain the black contents, then fill with fresh water, then drain again.
Today when I tried to pump fresh water into the black water tank, it would not flow.
Could it be the check valve?
I have a 2005, 28' Intl. CCD.
02-15-2009, 01:22 PM
Hernando
, Mississippi
could it be frozen?
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
02-15-2009, 02:51 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
What method are you using to get fresh water back into the black tank, A tank rinsing system, Flush King, or through the toilet bowl?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-15-2009, 03:07 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Managing one's "Ecology"
Hi, I have a 2006, and the flushing nozzle can get clogged with - uh stuff. Yeah, stuff. So.... your choices are, (1) fill the tank 3/4 full through the toilet, hitch the Airstream and rock back and forth until the wave action gets a chance to work it's way through the flush nozzle - oh and don't put the cover on the flush hose inlet - so that there won't be any back pressure to prevent water from circulating through the head of the nozzle. Drain the tank and repeat until the water exiting the tank is clear. (2) make a solution of enzymes designed to clear a septic tank and pour them into the black tank via the flush input - let it sit overnight and hope it dissolves any - uh stuff - that might have clogged the nozzle. (3) pull the nozzle and clean or replace... or chicken out and take it to a qualified repair shop. I'm sure they would appreciate it if you cleaned the tank thoroughly and deoderized it with something like a quart of clorox added to the last rinse!
Good Luck, Paula
02-15-2009, 05:21 PM
More than one rivet loose
Los Alamos
, New Mexico
Mine died after three months. Even when I had my black tank replaced we did not bother to clean it. It is worthless. I use a flush king followed by several gallons of water and a bag of ice before I hit the road. This scrubs the tank and leave nothing to get stuck in the drain valve.
Michelle TAC MT-0
Sarah, Snowball
