Old 08-01-2016, 04:59 PM   #1
cbrittan's Avatar
2016 30' International
Woodstock ON , North Fort Myers FL
Black Water Tank Flush: Park Water Pressure
Can anyone help us determine if the "black water tank flush intake" pressure on our 2016 AS 30' is protected against over pressure by the factory installed water pressure device.
Our park and other parks in which we have used the black water tank flush may have very high water pressures and volumes. We know the delivery of park water to the kitchen/bathroom taps are protected against high pressures by the factory installed device, but Is the black water tank flush intake and supply to flush the black water tank, also protected?
Your insight will be appreciated.
cbrittan is offline   Reply With Quote
Old 08-01-2016, 05:16 PM   #2
2007 22' International CCD
Nope, it's not protected against higher than normal pressure and flow.
I always use a quality adjustable pressure regulator at the campground water spigot to protect my hoses and AS.
KE4GNK/AE
Old 08-01-2016, 06:32 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
The sprayer in the tank is also not protected from getting clogged by TP and other substances which can dry and reduce the flow. A good high pressure of water can help keep it clean.
This is the strangest life I've ever known - J. Morrison
The Nest Egg - 2015 Airstream International Serenity 27FB
Quicksilver - 2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 06:41 AM
black tank flush - pressure regulator? bradk Waste Systems, Tanks & Totes 12 04-30-2006 07:08 AM
Black Water tank flush leaks bfwoz Waste Systems, Tanks & Totes 2 07-06-2004 05:06 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 12:54 PM
